Come in radio france...
Posted by: Naheed on 23 October 2002
I seem to be picking up some french radio station through my right speaker, anyone know whats happening...
I noticed i today when moving some cables, it was faint, is this just RF pickup or something else.
naheed
Posted on: 23 October 2002 by Roy T
I think this indicates a continued swing to the right in Europe . . .
Posted on: 23 October 2002 by minime
i had the same problem years ago ion amp rega 2 every sunday afternoon for some reason, then i noticed a sat dish pointing at the arm of the rega in my bedroom the further it went near to the centre spindle the louder it became.moved the rega out of line of fire problem solved, weird one just a thought. confused confused confused
Posted on: 23 October 2002 by Manu
After 20 centuries, France has finally found a way to invade England. big grin
Emmanuel
All opinions are my own, and reflect those of the organisation i work for, even if not stipulated.
Posted on: 24 October 2002 by Peter Stockwell
Emmanuel
Have you been to London recently ?
Peter
Posted on: 24 October 2002 by Manu
Peter,
Not really, only at Heathrow airport during my last trip to Salisbury.
Emmanuel
Posted on: 24 October 2002 by Trevor Bennett
I started picking up radio Romania(great amusement to my friends) when i went active.Naim did something to the snaxo which stoped the interference.
Posted on: 24 October 2002 by Steve Hall
....... Any idea what? As my active system gets some eastern block radio depending on the weather.
Posted on: 24 October 2002 by jacques (JD12)
_naheed_
It was Marianne Faithfull singing live from the Olympia (Paris)on France Inter big grin
Jacques
Posted on: 25 October 2002 by Bruce Woodhouse
Seriously now folks!
This was the subject of the first post I ever put on the forum (sigh). I used to get foreign radio through the system and it always seemed to be during high pressure weather! It lasted for years.
Nobody could really help on here, the problem was not volume dependent so I assumed it was interference downstream of the amps in some way. Unplugging my tuner was no good and fiddling with cables etc at the back of the rack no help.
But finally I sorted it. The problem seemed to be caused by the proximity of the speaker cable to a power lead extension well away from the system as it ran along the edge of the room. When I moved this (accidentally) it dissappeared.
I have no idea why/how this can happen but I'd suggest looking carefully at the speaker cables and any power flex close by. If your problem is different (ie rises in volume with the system) then it must be closer to the source.
I do hope this helps.
Bruce
Posted on: 25 October 2002 by Naheed
Turns out the spare hydra lead, was picking it up, now all I need is to boost the signal, then I have a free tuner !!!
naheed
