Pure streamer from Naim?
Posted by: T38.45 on 21 May 2009
Hi, will Naim build a pure streamer?
Posted on: 21 May 2009 by spacey
id buy one would be nice if naim could find the space in the SN as an optional extra like the r323 port
Posted on: 21 May 2009 by goldfinch
Hi, I don't think you will find here answers about these sort of questions about new products.
Anyway, my bet is Naim will launch streamers in a near future. It looks pretty logical once you are marketing DACs. A two box music server solution (streamer + DAC) and you just have to use a NAS or a computer as storage solution.
HDX (plus DAC as an upgrade) for those who don't want to deal with computers.
Posted on: 21 May 2009 by David Dever
Depends on what you want it to do, and how...in theory, the Uniti should be able to perform the same function as a typical Linn DS unit, at a much better performance level than the Sneaky DS–and with a decent CD player as well.
Also–one very important point–I feel that the "Multi-room DS" bit is a misnomer, inasmuch as a true multi-room system should be able to send synchronous streams to multiple zones, just as a traditional analog matrix switcher system can.
The Linn DS units cannot, but NaimNet can–and can do video as well.
Posted on: 21 May 2009 by T38.45
just like a Linn DS with Naim sound, with or without DAC...
Posted on: 21 May 2009 by Guido Fawkes
I doubt it; after all Pure never built a Naim portable radio AFAIKquote:will Naim build a Pure streamer?
The NaimUniti might be what you are after
Posted on: 21 May 2009 by pcstockton
I sure hope not..... I dont want Naim to make computer peripherals.
If a router cannot affect the SQ, I wont expect the streaming solution to either. A DAC is all you need.
A streamer without a DAC? What for? Then what's next? Naim Router, Naim Modem, Naim HDs, Naim mouse, Naimmini?
-Patrick
-Patrick
it only needs to be the size of a matchbox so could fit into an existing product. like dacs pres amps etc.
Posted on: 21 May 2009 by Steeve
It is. But without a CD player and amplifier please!
Steeve
...and on HDX level please :-)
I thought the OP asked about a "pure" streamer. I took that to mean, it does nothing else.
This is exactly what I do not want.
The HDX, Naimnet (and uNiti I suppose) satisfies that portion of the market... and quite well.
Steeve
a dac with wireless streamer - what i think all dacs will and should have in the future.
Posted on: 21 May 2009 by gary1 (US)
-Patrick
HDX!!
Actually PC, I'm curious to hear your opinion after the DAC is released in a computer set-up vs. the HDX/DAC combination.
My guess from what I've heard is that there will be a big difference in music quality for a variety of reasons, including the music player portion of the HDX.
But, we'll see.
HDX - internal disks - cd slot + better dac = perfect streamer....that's what i mean!
I'm running a HDX/XPS so this sounds great but i do not use the internal disks:-) all my music comes from NAS!
AmeriGary,
Yes sir... that will be my first demo.
My current PC with Naim DAC vs. HDX with Naim DAC.
I am not going to get into who or what does the rips quite yet. I am going to concentrate on what is feeding the DAC and if that makes a sonic difference.
Given that the HDX is out of my budget and especially if it can be improved upon by the eventual Naim External DAC, I will start with a Naim DAC. That is a given.
If the HDX improves things dramatically, I suppose I am screwed. Well my plans on buying a house are
I dont expect the HDX to make a huge difference though.
It will probably still just be merely a very nice ripper and hard disc player. I cant imagine buying an HDX for this very limited application...
-Patrick (very excited to hear the Naim DACs)
Posted on: 21 May 2009 by pylod
HDX - much much bigger internal disks - cd slot + better dac + all in one box= perfect streamer....
Minus the disc-ripping and internal storage, the HDX would still be a server, not a streamer (probably best termed a "stream renderer" or "stream player"). And a network file player (not a stream player).
Posted on: 22 May 2009 by pcstockton
quote:Originally posted by David Dever:
"stream player"
exactly what I dont want. I use Foobar... and will until something better comes along.
Posted on: 22 May 2009 by goldfinch
Me too, if Naim DAC is mainly aimed to computer audio it should give its maximum performance through it. A computer is perfectly capable of stream top bits if properly setup. A dedicated streamer would be nice though, but IMO more because of convenience than because of performance.
Posted on: 22 May 2009 by T38.45
...so did NAIM show the DAC in Munich?
Posted on: 22 May 2009 by spacey
quote:Originally posted by goldfinch:quote:Originally posted by pcstockton:
what would be nice is if the dac had a built-in streamer and connected to a laptop which you could download and install naimnets media playing software onto. then you music could be on a computer system as before. the only thing needed is the sofware really but a nicely synced streamer is an advantage its like the AE/itunes setup only 24/192 and with a proper dac.
Posted on: 22 May 2009 by james n
quote:what would be nice is if the dac had a built-in streamer and connected to a laptop which you could download and install naimnets media playing software onto. then you music could be on a computer system as before. the only thing needed is the sofware really but a nicely synced streamer is an advantage its like the AE/itunes setup only 24/192 and with a proper dac.
Sounds like a Linn DS player.
Posted on: 22 May 2009 by JYOW
Yes we so need a Naim DS player. I would buy that in a heartbeat. Even if it mean I have to part with my much loved Transporter.
hi JYOW, same for me...i would sell my hdx for a pure streamer now i know what streaming can do!
I will GLADLY take it off of your hands for $3500.
i just need the naimnet media player and the streamer
