Speaker advise
Posted by: Lars on 11 October 2001
I currently have a pair of KanII (latest version) speakers. These speakers does the PRaT thing like no other speaker I know of, but I realise that I can't live with this speaker in my current system. I also realise that I will get much more out of this speaker if I spend more money higher up in the chain. What I want to do is to get a bit more "round earth" sound without changing the rest of the system and without spending huge amounts of cash.
Any suggestions?
Current system: LP12/Lingo/Ittok/K9 (I know! K9 sucks) / CD2 / Nait3 / KanII + KanII stands and naim speaker cable).
It Kan be done!
easy really
Mullet Audio
Get some kelidhs ![]()
Scott
All suggestions are welcome.
It Kan be done!
Next, does the sound of vinyl and CD differ markedly. If one is OK, while the other is terrible, it suggests a problem at the source rather than the speakers. If its the turntable, I'd suggest you talk with Linn or Expert stylus about buying a re-con Karma or Troika, this will definitley fill out and smooth the sound out.
If both are as bad, check the set-up of the Kan's, make sure they are nice and steady. Try moving them to the short wall, if they are currently on the long wall or vice-versa. This may well help.
You may wish to try a Mana sound-stage under the speaker stands. I'd suggest you give Mana a call if this appeals. In my experience, Kans can be made to improve dramatically by carefully considering the surface the stand sits on - it doesn't have to be Mana, a MDF platform screwed to the floorboards works well in woodedn floored rooms too - I'm not a fan of paving slabs though.
If on the other hand, all this fails or does not appeal, I'd suggest you try Shahinian Super-Elfs on good stands. They can really sing, have tuneful bass, yet are much more 'round-earth' than Kans.
As ever, use you ears.
The Epos es11 is a good match to your system. Probably the es 12 too.
You can most likely get hold of a secondhand es 11 at about 3500 SKR (About £250)incl. stands here in Sweden.
I know that HiFi Art in stockholm has a new pair of Es 12.(Naim dealer)
If you like the Es 11 try removing the spikes facing the speakers(not the spikes facing the floor) and place Sonic designs SD foten between speaker and stand. Makes a big improvement on a already great little speaker.
Greetings/Hälsningar Gunnar
Try listening to the latest ones, they haven't been out long and they apparantly have a whole bunch more bass than the old model
Scott
/Erik
Gunnar
/Erik
Hmm..dunno..we'll put it down to a difference in testing then I think, I certainly seemed to prefer them.
BTW you are from 'the Midlands' care to elaborate as Kidderminster is obvioulsy also there. Also where did u listen to the Ela's?
Scott
Steve
Contact me if your kans are not black and You have decided to sell them. If needed I can pick them up in Malmö.
/Tomas
