To ERR is to CD 3.5
Posted by: Stephen Bennett on 05 June 2001
OK. My used CD 3.5 arrived today. It was well packaged and had the transit screw in. Loading a CD and pressing play gives me the ERR message. There's a 4 pin doobrie covering the 2 DIND on the back which I assume is right, leaving the last DIN for output.
Any ideas whats up?
Posted on: 05 June 2001 by Stephen Bennett
I what way?
regards
Stephen
Posted on: 05 June 2001 by mr saucisson
has it got the magnetic puck that sits on top of the CD when playing?
Also try other CDs, I have quite a few that are a bit reluctant to play in both a CD3.5 and CDI.
Ben
Yep, the puck is there. Further investigation - the laser just 'clicks' when i press play or a CD is loaded. Bugger!
Posted on: 05 June 2001 by John C
Aren't there two transit screws?
John
Thanks Guys. I spoke to my dealer (handy when you are old school friends!). I think it's knacked (he didnt even say 'I told you to get a new CD5'!). Time to contact the seller methinks
Stephen
"My 3.5 only has one, to hold the tray in."
Mr Pig you seem to be making a habit of buying dodgy Naim kit.Better a sheep than a goat you know.
John
Posted on: 05 June 2001 by Mick P
Jonathan
The newer models have a 2nd screw to hold the main PCB rigid during transit. Too much bouncing about can cause soldered joints to shear/snap.
Its located in the center of the floor panel. Pig has an old model. You and I have newer versions.
Mick
Posted on: 05 June 2001 by Chris Dolan
Surely it is lowering the tone to discuss the number of screws, rather than debating the quality of the puck.
Stephen
As your dealer is an old (good - presumably)school friend, why aren't you buying S/H via him?
Chris
Posted on: 06 June 2001 by Stephen Bennett
he didnt have one, thats why!!
Stephen
Posted on: 06 June 2001 by Chris Dolan
Well that's alright then!
I just thought he might know of other customers who were looking to upgrade that he might have been able to put you in touch with.
Presumably the player's still not working? Any joy with the Seller?
Chris
Posted on: 07 June 2001 by Stephen Bennett
...and this one was only 450 quid so I cant complain, even If it needs a new transport. The sellers on holiday till the weekend (poor sod - great holiday return. He's a decent sort.
Just a pain really
Whats the Naim turnaround like?
Stephen
