Does Naim DAC capble for 24/192 playback?
Posted by: Naruto on 18 January 2010
does Naim DAC capble for 24/192 playback?
For example: Linn sneaky Coxial to Naim DAC, 24/192 flac playback?
Posted on: 18 January 2010 by gone
If by coaxial, you mean S/PDIF, then yes...
From the data sheet:-
Sample Rate
USB 32kHz to 768kHz, 24bit
S/PDIF 32kHz to 192kHz, 24 bit
iPod, iPhone 48kHz max
John
Posted on: 18 January 2010 by Chaton
Just to make a correction Frown From manual)
DAC Specification
Input connections: 4 optical, 4 coax, 2 USB
Outputs: DIN or RCA phono
Frequency response: 10Hz to 20kHz +0.1dB-0.5dB
Max output voltage: 2.2VRMS
Distortion and noise: <0.002%
Sample rate: USB: 32kHz to 768kHz, 32bit
S/PDIF: 32kHz to 192kHz, 32bit
Apple portable: 48kHz max
Digital formats: S/PDIF, WAV
Upgrade PSU: XPS, CD555PS
Mains supply: 100-120V, 220-240V, 50/60Hz
Dimensions: 70mm x 432mm x 301mm (H X W D)
Power consumption: <30VA
Weight: 5.6kg
Finish: Black anodised
