hi -cap/??/NAP250
Posted by: Jez Quigley on 05 February 2001
I think that,if you could find one,a 32.5 (serviced,72'd) would provide the most "Bangs per Buck" .
Chris
I much prefer a hicapped 72 to the 62, but they sound different. If you can listen to both before purchase, that would be ideal. I suspect that a service 42, 42.5, 62, or 92 wiuld all sound essentially the same.
My usual setup at the office is 32.5/SNAPS2/110, which is nicely balanced. However, I've run it with 32.5/Flat/110, 32.5/SNAPS2/250 and 32.5/Super/110. All of these sounded "good" (some better than others), so you should be fine.
What I can't understand is why you bought a 250 first. This means you're stuck scrimping on the pre-amp. You would have been much better off with a 102/Hi/110. Oh well, you've made your bed...
In the end your system will sound fine with 32.5/Hi/250. It could sound better with a different configuration for the same amount of money, but that's academic now.
-=> Mike Hanson <=-
Mickey Dale
"I bought a 72 about 5 years ago for £250 boxed"
WOW !Where do YOU go shopping ?
...and more importantly,what do you think you could get an 82 for ?
Chris
I've been trying for some time to get second hand a hi-cap/72/160or180 without luck. When a 250 came along for £550 (old but re-capped etc a year ago) I plumped for that given that most 180's are priced around/greater than that and 250's are the amp of choice for Epos 14's so I would have wanted to go there eventually anyway. Thanks for your comments, I appreciate it, and welcome more.
-=> Mike Hanson <=-
Can anyone put me straight on why when using line level inputs only, the pre-amp can make such a difference? I read on the forum about 'straight through boards that don't take any power from the rails' so I'd like to understand why is there a big difference in pre-amps performance?
My personal order of preference would be;
(1) 72 (2) 32.5 (3) 62
There seem to be some 72 bargains to be had,but if you can find a cheaper 32.5 (serviced,72'd),then the differences between the 72 and 32.5 are not that big,and I would expect the 32.5 to be less expensive (depends on fiancial situation)
Chris
While I'm in a cash slapping frenzy I'm going to get the s/h Numerik he has too. So, fingers crossed, when Saturday comes I'll have, what for me, is a dream system:
Karik III/Numerik/Hi-Cap/72/250/Epos14's
I'll be so skint now that I hope upgraditis leaves me alone....mmmm Isobariks for £450? mmmm...
