Having to keep logging into the forum
Posted by: Tabby cat on 01 July 2010
I really enjoy reading the forum
However lately I have to keep logging in eveytime I go to the forum
.Even if I tick the remember me for forums box.
Even last month you could always enter and livecloud would remember you.
Can anyone throw any light on this.
Cheers Tabbycat.
Posted on: 01 July 2010 by dave simpson
Still have the same problem even after using the new address. If you close the browser session, the forum logs you out. Browser is IE8, OS is Win7 Pro.
I can tolerate it as long it takes to get it fixed, it's just a bit aggravating.
Posted on: 01 July 2010 by joesilva
I updated the address and password and do not have the problem you've got Tabbycat. However, I'm running on Mac OS 10.6.4
The only suggestion I can make (if you have not already done so) is to delete Naim forum from your bookmarked web pages and start all over again, googling Naim forum, etc. I suspect your computer is somehow remembering the old forum address, or has not been able to reuse your password for some reason. I reset usually helps.
Joe
Excellent suggestion Joe! I reset IE to default settings, Bing'd "naim audio forums", opened the forum homepage and then reset my IE homepage back to the forum's homepage. After logging into the forum I closed the browser session and reopened. My login held now. I then rebooted my laptop and opened a new browser session after the desktop loaded and my forum log in is still holding.
thanks,
dave
Posted on: 02 July 2010 by Richard Dane
Dave, glad you got it sorted.
Posted on: 02 July 2010 by dave simpson
Thank you sir. A reset of IE's default settings (tools>Internet options>Advanced>reset) and remapping to the forum's homepage via linking with a web search fixed it.
Posted on: 02 July 2010 by Tabby cat
Thanks for the advice.I tried putting the new forum address in my favourites on my browser and it seemed to do the trick.
