What would be the best improve...
Posted by: rorominator on 30 September 2002
to this system ?
Naim CDX
NAC 102
NAP 180
Flatcap2
Nautilus 804
A Hicap ? a new preamp ? a new amp ? I'm interested in a pair of NAP 135.
I would like less harshness in medium/treble, more punch and more bass.
Thanks for your replies.
Naim CDX
NAC 102
NAP 180
Flatcap2
Nautilus 804
Posted on: 30 September 2002 by david r
An XPS for the CDX - completely changes the player IMO
CDSII, 52, 135's and SF Electa Amator II's
Posted on: 30 September 2002 by rch
Before you get a pair of expensive 135´s you should get a better preamp first. To run the 135´s you´ll probably need a 52. The Hicap instead of the flatcap would also be a good improvement and quite affordable.
What about a NAC 82 plus Hicap?
Good luck!
Christian
Good luck!
Christian
Posted on: 30 September 2002 by Hammerhead
I've just replaced my 102 with an 82 in a system similar to yours. Bags more of want your looking for/lots more music. Next would be an XPS, then Hi/Supercap, then 135's perhaps (well that's my medium term plan anyhow).
Steve
CDX/P25/82/Hi/140
Steve
CDX/P25/82/Hi/140
Posted on: 30 September 2002 by Philippe Dancause
IMHO a Hi-Cap or a super cap. This will be needed for a 82 as well...
Posted on: 30 September 2002 by David Patterson
Hi , my system is fairly similar to yours..
NAIM CD5
HI-cap
NAC 102
HI-CAP
2X250S
804s
I HAVE USED MY 804s WITH 150 AND 180 POWERS AND NOT UNTILI GOT THE 250 DID I FEEL THAT THEY WERE BEING PROPERLY DRIVEN/CONTROLLED.THE SOUND WAS ALWAYS ENJOYABLEBUT YOU KNOW THAT FEELING WHEN YOU ADD SOMETHING NEW AND WHEN YOU PLAY A FAVE DISC AND YOU GET GOOSEBUMPS.ADDING THE SECOND 250 GAVE MORE OF THE SAME WHILST ADDING MORE WELLY AND AMAZING MID UPPER CLARITY.I KNOW THAT I AM ONLY SCRATCHING THE SURFACE OF WHAT THESE SPEAKERS ARE CAPABLE OF .GO FOR A SECOND HAND 250.
REGARDS
DP
NAIM CD5
HI-cap
NAC 102
HI-CAP
2X250S
804s
REGARDS
DP
Posted on: 30 September 2002 by Bruce Woodhouse
Cheapest, cheap, not so cheap.
Napsc, Hi-Cap, XPS.
Each makes a difference in the areas you mention, the XPS is a real jump but you are not going to get real value without improving power supplies to the 102 as above, or getting a different pre-amp as suggested-which needs at least a HiCap anyway. The power amp upgrade to 135's id not a priority yet I would say.
Bruce
Napsc, Hi-Cap, XPS.
Bruce
Posted on: 01 October 2002 by Jay
Hiya
I basically had an identical system to yours about a year or so ago (excepting the speakers)
CDX
102 (NAPSC)
FC2
180
Credos
If you don't have a NAPSC - I'd do that first. I've been told that the latest new one from Naim is quite an improvement....
Next? Well irrespective of 82 or XPS arguments I'd go with a hi-cap. It's a good long term investment, easy to sell on and really makes the 102 sparkle.
The next step is more contentious. I got an XPS and then an 82, but I was constrained by what was available on the 2nd hand market. Now that I have the benefit of hindsight (not that I could have actually benefited from it!) I would probably plumb for the 82 before going for an XPS.
Why? Well the XPS on a CDX through a 102/hi was a major improvement but I think the 82 is quite a big gain on the 102. An additional bonus is that any other sources you have also benefit. Don't worry about the bare CDX being outclassed by an 82 it definitely isn't (until you put an XPS in there are hear what you've been missing
The only qualification I'd give is that I don't know your speakers at all. Best to demo the options at home if possible.
All IMHO of course
Jay
Yabba, dabba, doooooo
CDX
102 (NAPSC)
FC2
180
Credos
All IMHO of course
Jay
Posted on: 01 October 2002 by bob atherton
Get a NAPSC then enjoy what you have until you can afford the XPS.
Bob
Bob
Posted on: 01 October 2002 by NB
If it was my system I would add an XPS first and then look towards replacing the 102 with an 82 or even the new 282.
After that I would look towards a Supercap followed by a pair of 135's.
You will be able to hear a noticable improvement with each upgrade.
NB
NB
