Naim launches the HDX at this week's 'High End' Show in Munich
Posted by: Steven Hopkins on 23 April 2008
This week sees the launch of Naim's HDX: the World’s first, performance upgradeable, audiophile hard disk player.
The High End Show takes place at the MOC in Munich from 24th to 27th April. The HDX will be available for demonstration at the High-End Show in Room C120 where Naim's German Distributor, Musicline, will be exhibiting. For more information about the High End Show http://www.highendsociety.de/deutsch/highend/highend_aktiv.php
Further information about the HDX will be available on the Naim website from Monday 28th April.
Posted on: 23 April 2008 by hungryhalibut
Will the information on the 28th include when it will be released and how much it will cost?
Posted on: 23 April 2008 by Huwge
I hope to see this in the flesh, as it were, on Friday (if I can get the day off) and so will see what information is to be had.
Posted on: 24 April 2008 by Jet Johnson
...From today's What HIFI news section......
This is Naim’s new HDX, launched today at the Munich High End Show and described as ‘the world’s first upgradable audiophile hard disk player.’
The £4500 unit, which will go into the shops in August, uses twin 400GB hard drives, one acting as a back-up for the other, and can be upgraded with the use of Naim’s XPS or PS555 external power supplies.
The HDX is said to deliver ‘the performance of a Naim audiophile CD player with the convenience of a good MP3 player’. It rips CDs at fuil .wav resolution – 16-bit 44.1kHz – and, via a combination of the right drives, no caching, reading the disc at least twice and taking into account errors, gives an accurate bit-for-bit rip of the disc.
The data is stored on one of the two 400GB drives, which is backed up overnight onto the second drive. The HDX can also work with external USB drives or Network Attached Storage devices, and has a database system tested for up to 20,000 CDs.
The Naim Extended Music Database system will find disc details and cover art, and allows searching via a number of parameters including title, artist, composer and so on.
In addition, the unit can store non-DRM downloads of 24-bit/88kHz and 24-bit 96kHz, with Naim’s own record label planning to join the ranks of sites offering such downloads later this year.
The HDX can also play music from a network or from an MP3 player connected to one of its USB sockets, and can also stream to up to six StreamNet devices on a network. It can be controlled via the front-panel touchscreen or the remote handset, or using a monitor or mouse.
It uses a toroidal transformer for the audio section, which is built to Naim’s usual high standards, and can double as a CD player thanks to the built-in drive.
Posted on: 24 April 2008 by Right Wing
Thanks for that. I am very interested in this.
Peter
Posted on: 24 April 2008 by Cjones
So this unit doesn't work with Netstream? Looks/sounds a lot like what a NS 03 is/was going to be?
Posted on: 25 April 2008 by David Dever
It sure does–six streams, just like the other servers, but with a focus on local analogue sound quality.
Posted on: 25 April 2008 by Volker
I've been there today, really great sound and demonstration, like every year Winker
Unfortunately no possibility to compare to a CDX2 or something, what would be really interesting, if the HD has also advantages in sound to CD (better error correction).
