Is the Mac Mini such a mediocre transport?
Posted by: Guido Fawkes on 27 June 2010
Sorry for the controversial title, but according to Item Audio who make a rather good looking Digital Audio Transport.
The computer is an issue: Mac Mini and MacBook owners are effectively denied coaxial connection without resorting to potentially lossy converters, so optical and USB are preferred. Yet even comparing similar Apple platforms, the Mac laptop's USB implementation is audibly superior to the Mac Mini's USB output! On a desktop machine (regardless of OS), the choice of coax-bearing soundcard (located in the worst possible place for an audio component) will greatly impact on the sound quality
excellent results are now possible using USB digital converters outputting S/PDIF over coaxial or optical as well as AES/EBU and I2S
an Apple machine is ... a nicer machine ..., but the bottom line is you have to break the case to control EM interference, the power supply is nasty, and iTunes sounds bad. Pure Vinyl player greatly improves sound quality but we've not heard a Mac yet (desktop or portable) that betters the system specified ...
The system specified is
Zotac Ion ITX B-E N230 Atom Motherboard
Pico PSU 90 DC Power Supply
Item 12V Regulated AC-DC Converter
Western Digital Caviar Green 1Tb
50cm SATA Extension cable
Apple Slim Keyboard and Optical Mouse
Alternatively, if you have an iPod and fancy putting it at the heart of a high-end system in which it becomes a digital transport as good as any available .... Audiocom-modified Wadia 170 iTransport
I'm not saying the author is right or wrong, but his logic best read in context seems sensible for the most part - anybody got any views?
The last suggestion is where I came in on this digital lark and if it is better than a hard disk computer system is certainly a very attractive way to use the Naim DAC.
Posted on: 27 June 2010 by garyi
I don't really know why it is sensible. Its just opinion. In his opinion
Opinions are like arseholes, we all have one.
Posted on: 27 June 2010 by Guido Fawkes
Sensible is the sense that I've always found Apple power supplies a bit ropey. I was looking for ways to improve my Mac in to the Naim DAC (probably go for the HiFace) when I came across this article.
Posted on: 27 June 2010 by PMR
Surely you just need a 'bit perfect' source to get a perfect sound Winker
Posted on: 27 June 2010 by js
I'd rather have a completely perfect one. Why just a bit? Big Grin
Eek You mean a bit is not a bit? Shocking stuff!
Posted on: 28 June 2010 by Eloise
I think you totally sum it up in the first sentance ... they make a good looking Digital Audio Transport, so they find the possible negatives in the MacMini.
They rubbish TOSLink, but then their basic computer doesn't have anything other than basic TOSLink and Co-ax off the motherboard which is likely to be worse. There is also an argument which does stand up that using TOSLink provides a totally galvanically isolated signal path so actually is an IMPROVEMENT over Co-ax SPDIF.
At a basic level, their computer is just basic off the shelf parts put together with a linear PSU - which may provide an improvement but may not. I'm not even sure if the linear PSU bypassed DC-DC converters which are often a worse contributor to SQ than an external linear PSU - remember that the UnitiServe (IIRC) uses a basic laptop-style power brick which is likely to be SMPSU.
They also rubbish iTunes which is just an opinion which many people hold a counter opinion to. On top of that - the price is quoted as "from £595" forgetting to mention that on top of that you need an operating system £180 is the price for Windows 7 Ultimate.
At the end, they also suggest using Songbird on (I assume) Linux ... but to my knowledge Songbird is unable to use Memory Play mode (as they claim) and wasn't considered bit-perfect - it's difficult to disable sample rate conversion - (edit: I may be wrong here).
At the end of the day, the comments about the MacMini are more about marketing and promoting their own product than any real differences. Once you add a good FireWire DAC, or USB to SPDIF converter to the MacMini, the only problem left is the PSU - and that is often considered a non-problem.
Eloise
PS. This isn't really about MacMini at all ... his comments are about any general purpose computer vs. Item Audio's digital transport.
It's about how much store you set in linear PSU vs. switch mode PSU as this is the only thing "special" about the Item Audio device - the rest is pretty much off the shelf assembly.
Posted on: 28 June 2010 by Andy S
It's not clear what is and isn't included, but the cost of all that excluding a case is going to be around £400 (assuming they include the stated 4Gb RAM and a BR drive). 4G of ram is overkill (even for video) and I'd much prefer the dual 330 core over the single 230 so it's not clear what a "sensible" system price would be. It's also interesting to see they say it is silent. So far, in my experience, the 330/Ion can't run totally passively with the heatsink supplied on the Zotac board.
It'd be interesting to find out what playback software they would use. The website says they will install linux Ubuntu s/w for "a fee". It would also be interesting to see what that fee is since the Ion system is basically supported out of the box on Ubuntu so it's a 45 minute job in total.
As to sound quality - we will be comparing a mac mini with amarra to a zotac ion/xbmc based system into the nDAC in a couple of weeks. Stay tuned for more info...
Posted on: 28 June 2010 by Guido Fawkes
Thanks Eloise
Using a MacBook Pro, which I already have, does seem to be an easy way for me to play downloaded music on the Naim nDAC, but I'm not happy with the performance through optical out compared with USB sticks. I think I'll get the new HiFace EVO.
Would you agree his specific statement
is it just more marketing hype. Only thing I can think of is that the Mini's internal SMPSU may be noisy.
I don't like Apple's external PSUs and have got the odd spark or two from some - wonder if there is a better PSU for my Apple MacBook PRO.
ATB Rotf
Posted on: 28 June 2010 by james n
The mini doesn't have an internal SMPS - its in an external brick. The two USB outputs may sound different - but then i'd put this down to the connected DAC being susceptible to noise fed via the USB cable from the host computer coupling where it shouldn't. They also dont mention whether this sounds better when the Macbook is running from internal or external power, specs of the different machines etc etc. If you've got a Mac then forget USB and use Firewire.
James
The new Mini is internal.
This whole "advertising" sounds very negative on the way they beatup on a MacMini and MacBook - that kind of advertising always turns me off. Say how they feel they have improved, then let people make their own mind up - especially as the improvement is over ANY general purpose computer NOT just a MacMini. Generally that company has made some questionable claims e.g. iPod with Wadia dock (modified by them) is better than any computer with 16/44.1 material.
As for MacBook vs MacMini, I have seen elsewhere comments that running a MacBook off battery can improve the sound so this is probably what they refer to.
Eloise
Very true - but then Item audio weren't referring to the latest slimline version ?
I still mean to try a Linear Supply on my Mini - i have the cable but finding a beefy 18v supply is more difficult without borrowing one from work.
James
Thanks James
Ah so the Item Audio is just marketing nonsense then - didn't realise Mac Mini had external PSU - for some reason thought it had internal one like PowerMac/iMac - must be getting old.
Naim DAC does not accept Firewire so need a converter - M2Tech's USB to S/PDIF seems an inexpensive solution, whereas Firewire to S/PDIF is a bit pricey.
Is the INT202 worth the extra?
Had thought it's lack of a BNC interface might negate the advantage of Firewire over USB - but this is mind over ears again as I've never heard the thing. Plus I need to upgrade to Leopard or Snow Leopard to try it - suppose that is not a bad idea.
Many thanks, Rotf
ROTF - i'm sure Allen B compared both the Hi-Face and INT202 into his nDAC - worth a search back.
James
