Best Recorded / Best Sounding Compact Discs?
Posted by: Kevinbro on 22 January 2002
I have good Naim gear (CDS2, SCAP, 72, 135s) and I love CDs that project a true realism (live or in studio)!
Thanks,
kevin
Peter
Cowboy Junkies - Lay It Down, Trinity Sessions.
Nick Cave - Murder Ballads
La Bottine Souriante - Rock and Reel, En Spectacle
Diamanda Galas - Malediction and prayer(you won't like it though)
and many more.
cheers
Nigel
Peace Orchestra (Peter Kruder's orchestrated downbeat dance-fest) is amazing.
Leggo Beast "From Here to G" beats you into submission and then scares the [lah-dee-dar] out of you on the track 'Tumbledown'
Ben Vaughn, "Paint it Black" - fantastic swinging rock and the recording really does it justice.
Andrew
Andrew Randle
Currently in the "Linn Binn"
On the Sony label, unfortunately it may be out of print - the Kodo site doesn't even mention it.
Keith.
Run, Lola Run - OST - Great electronica
Ghostyhead - Rickie Lee Jones
Shakti - The believer ... Jazz / Indian fusion
Colin Lorenson
Japan-Tin Drum
Robbie Robertson-Robbie Robertson & Storyville
Jazz at the Pawnshop
SFX, Electric Glide and Acoustic Revenge are remasters rather than original recordings: still good, but not as good as the rest.
The ones Ken Christianson recorded straight to 2-track are at least as vivid as any other recordings I've heard. Which you select depends on your tastes, of course: anything you particularly like or hate?
Pete.
Can't say a lot about the music though...
Keith.
Paul Rodgers - Muddy Water Blues c.1993
Keb'Mo - (1st. album) c.1994
Stunning Music, Stunning Sound.
Keith.
Any one explain how that can have happened? I'm sure the fore mentioned Dad charges less per hour than most studios.
Jonathan
I must admit that I'm not convinced about the Trinity Sessions as there are a lot of noises in the background (not just background noise if you know what I mean!) which I find annoying.
Steve
In that case don't even think about getting Over The Rhine's "Good Dog, Bad Dog", where even the sleeve notes point out you can hear people moving the furniture and the piano creaking quite a bit. However, if you want to hear good music recorded simply and emotively, and if you like the likes of the Cowboy Junkies, then very heartily recommended.
It doesn't really bother me, in the same way as people with colds at a concert don't ruin it by the odd cough.
Pete.
Studios let you monitor things closely on a multitude of cannels, do stuff like overdubs easily, work with different musicians at different times and provide accoustically neutral spaces where the room doesn't come into what goes on. These can be handy, but certainly aren't necessary.
Note how most of the naim CDs are recorded outside of studios, simply by selecting an accoustic space that suits the artist and careful positioning of two very good AKG mics therein, followed by recording straight to two-track. Since the music is all "live" (as in played by the band in one take with all parts happening at the same time) studio facilities for other setups become largely irrelevant.
So it depends on how you're recording whether a studio will be an asset or a great way of burning money unnecessarily.
Pete.
Everythings Fine by Willard Grant Conspiracy
If you have even the remotest prejudice against alt. country this one will sort you out. Glows beautifully thru a 72/180
Best recorded CD I own.
If you want to find out if your system can do drums this is the one to find out with.
Alex
Rolling Stones live att Camden Theatre 1964-03-19. Only available as bootleg, but sounds superb. It was recorded by the Beeb as test broadcasting in stereo.
Early stuff with Jonathan Richman sounds like it was recorded in the living room. Maybe sounds more "interesting" than actually good!
Janis Joplin, Trouble in Mind. Here someone is typing on a typewriter. Loud and clear.
I could probably go on and bore you for ever / JohanR
