Interconnect Upgrade
Posted by: markjp on 11 December 2001
thanks
Mark
I note that you have Celestion A2's which can be a difficult load for a 140. If you're finding the sound quite bright, the Solid2 or anthem could help. However, there will be a trade-off in terms of musical cohesion so watch out for that!
If you are getting a bright sound, try putting the flatcap between the 62 and 140. Although this goes against the source first principle, the extra juice the 140 will get, combined with the better regulation of the preamp and the softer sounding CD3.5 may be a better balance. Try it - it can't hurt (provided you switch off the amp and power supply before unplugging anything).
Frank.
All opinions are my own and do not reflect the opinion of any organisations I work for, except where this is stated explicitly.
I only paid 30 quid for mine used so I'm quite happy but between a 62 and 3.5 I'd expect any improvement over the Naim cable to be limited.
Steve
When it comes to interconnects stick with Naim, the Chord may seem an improvement at first - but gradually you realise something is a miss - then use your SNAICs to restore balance to the force...
naheed
If I didn't already own the Anthem, then I wouldn't go out and buy one for my Naim system. However, if I had a non-Naim system with no free interconnects, then the Anthem would be top of my list.
Have decided to stick to NAIM cable as suggested snd not try Chord cables. I am going to upgrade my grey SNAIC for a black one.
I am going to concentrate on saving for a Hicap for my NAC62. Hopefully will be able to afford one in 2002.
thanks
Mark
Originally posted by Vuk Vuksanovic:
Mark.A Snaic does not go between CDP and pre-amp.
Vuk.
What is the interconnect between a CDP and Pre called then? and is it now black, as my dealer says he is going to order me one. I'm getting confused!
Mark
Originally posted by markjp:
What is the interconnect between a CDP and Pre called then? and is it now black, as my dealer says he is going to order me one. I'm getting confused!Mark
The interconnect between source and preamp is just called interconnect, as far as I know. It's not black but grey. The newer interconnects have a grey/lavendel colour.
Snaics are the cables used between preamp, power amp and power supplies. Apart from the signal they carry power as well. There is a 5-pins version (pre amp to power supply) and a 4-pins version (pre amp or power supply to power amp).
Ciao!
Willem
Frank.
Later
Doug
Later
I ordered from my dealer a 4 & 5 pin SNAIC, one to replace my NAC62 to NAP140 connection and the other from a Flatcap to CD3.5. What I didn't realise was that the Flatcap to CD3.5 was already Black. My dealer can't refund my £53 because it was a special order from NAIM, however I was hoping that if there was an improved Interconnect to CD I could exchange it for that.
thanks
Mark
The latest interconnect is of grey/lavendar appearance. The construction differs slightly to the predesessor in that the braiding is only soldered at point of contact with the DIN and the braid is not tinned along it's exposed length.
Sounds good to me.
Oh and another thing Mark. If you'd like to swop the unrequired Snaic for the latest interconnect let me know
Later
Doug
At least I think I have, do I remove the no spam bit. i.e doug@........
thanks
Mark
