If I were to buy a Mac mini....
Posted by: Tony Lockhart on 11 October 2008
Finding people with experience of Macs is impossible! Even my company's IT dude knows nothing about them.
If I bought just the base unit is it at least likely that my keyboard, mouse, monitor etc would be compatible? Otherwise the change over will get a tad more costly.
Tony
Tony
Posted on: 11 October 2008 by Sir Crispin Cupcake
Tony,
Your mouse and keyboard will be compatible as long as they're USB, if not you could get PS2 to USB adaptors. Apple include a VGA adaptor which your monitor probably will accept.
I've had a Macmini for about a week now, and it is unbelievably simple to set up (think 20 mins) compared to PCs and seems very stable. I'm kicking myself for not buying a Mac years ago!
Rich
Rich
Posted on: 12 October 2008 by Tony Lockhart
Thanks for the replies. Seems like a sensible move for someone like me that never does gaming and has had enough of the usual Microsoft problems. I can't face Vista, and I bet its replacement will make even more printers etc redundsnt.
Tony
PS. This reply will appear a while after I post it at 10.14am because I've been a bad boy. Again. Sorry Adam, I'll try and grow up!
Tony
Posted on: 12 October 2008 by garyi
I have never encountered a USB mouse or keyboard that did not work. That being said special keys like media controls on keyboards might not work out the box.
If your monitor is VGA or DVI then you are set. If your printer is USB and not DELL then your are sorted there too.
Posted on: 12 October 2008 by Sandy8
Once you try Mac, you won't go back...
Posted on: 12 October 2008 by Sir Crispin Cupcake
Yep - they're fantastic!
Rich
Rich
Lots of help out there, just in case, like this.
I'm a bit of a numpty most of the time with compooters, so if I'm given the go ahead be prepared for daft questions. Thanks.
Tony
Tony
Tony if you find windows keyboards difficult for instance the @ and " are the other way round on mac keyboards, then get a mac keyboard, they are 30 quid. or a logitech mac keyboard.
Posted on: 12 October 2008 by Keith L
My children can grind a Windows PC to standstill within 3 months. 4 years ago I bought them Macs and I haven't had to rebuild a computer since.
Posted on: 13 October 2008 by Space Bunny
Hi there
My 2p.... have had a mac mini for about 2 years now, and I love it. I'd always used PCs before, at work and home. It just operates so beautifully. I would say though, if I could re-wind 2 years, I'd get one with a built in DVD burner. Maybe that's standard now, not sure. I'm really glad I didn't get another PC.
SB
SB
Posted on: 13 October 2008 by Wolf2
I just wouldn't go for anything but MACs. OSX has been so stable I don't ever see my tech guy or pay him money like I used to.
Posted on: 15 October 2008 by JonR
And Apple have just released some fab looking new laptops too! After an enjoyable two and a half years with an Intel iMac I have been thinking of switching back to a laptop for some time, and the new range (hewn out of solid billets of aluminium it would seem) look the dogs!
