CD2 transport ?
Posted by: Jonas_Bj on 08 August 2002
Hi,
Can anyone please help me.
I wonder wich transport my CD2 has.
My time is running short.
Serial: 116801
Have a look at the pics I have taken with my webcam.
http://w1.921.telia.com/~u92111504/naimbild/
Serial: 116801
Posted on: 08 August 2002 by Simon B
I belive that all CD2's used the CDM9Pro transport but I could be wrong.
Simon
Simon
Posted on: 08 August 2002 by rch
Jonas,
Like Simon I also did believe that Naim used CDM 9 Pro for ALL CD2 players. Comparing your "lens" photos with my CD2 there seem to be a difference to me. By serial number mine is quite a bit "younger".
So maybe one of our administrators could answer this question?
Christian
Christian
Posted on: 08 August 2002 by Jonas_Bj
I'm about to return the player. I have just bought it home for testing. I had tested much music now. But I can't make it swing as it should.
I think it's my table that sux. I will test the Nait on (modified) IKEA Lack. And the CD on IKEA Lack. Now the CD sounds a bit sharp and clean, it seems to be missing warm and swing.
/ J
/ J
Posted on: 09 August 2002 by Jonas_Bj
James.. where are you ?
/ J
/ J
Posted on: 09 August 2002 by rch
Does this mean, that the Pro mech is superior in quality than the standard mech?? And if so, what about Naim's philosophpy not to built a machine that would be worse compared to an existing one?
My CD2 does have that grey plastic mech.
Cost? It's still on warranty, anyway.
Thanks for an answer
Christian
Christian
Posted on: 10 August 2002 by Jonas_Bj
Yes.. thanks for that information
I will now let my ears decide if I like the CD2 better than the CDi. As far I can tell you, that I like the CD2 more. The both players swings almost the same, but the CD2 is more clear, real and natural. The CDi is a bit softer.
/ J
/ J
Posted on: 10 August 2002 by rch
Sue,
James,
Thanks for clearing that.
In Germany there is only one distributor for Naim products: Music line in Hamburg. They give a warranty of five years from the date of purchase for each Naim product.
Jonas,
I would like to suggest the CD2 to you. It's a really splendid machine! They only stopped it, because the CDM9 wasn't available anymore. On another post Doug Graham assured me, that Naim could keep the CD2 running for quite a while yet.
Christian
James,
Jonas,
Christian
Posted on: 11 August 2002 by Jonas_Bj
Sounds good. It has never been serviced. I will service it when it doesn't play CDs anymore. First I will service my Nait 1
I'm satisfied with the CD2. But when I service it, will they change to a worse transport?
/ J
/ J
Posted on: 12 August 2002 by rch
Jonas,
No, they have original mechs in stock, in order to remove yours if necessarily. But I think there wouldn't be a huge probability for that.
For further significant improvement on the CDP-path we'd have to go for the CDS2 IMO.
So enjoy it for a long while yet!
