Anti vibration amp stand
Posted by: DynaudioBoy on 01 June 2003
After reading posts about stands and their ability to improve sound, I searched around and found fraime and mana to be good and much talked about, little did I know they are very very expensive.
I have found a company that produces anti vibration stands for components that have the perfect balance between sound quality and price, hence good value for money unlike fraime in my opinion at over £1000!
it only cost me £60 I'm really happy with this with my setup NAP140/NAC72.
It has a glass shelf and four needle points.
Posted on: 01 June 2003 by garyi
So what you want us to guess?
Posted on: 01 June 2003 by DynaudioBoy
sorry the last bit of my post got cut of
the company name is rtc, and they call it an amp stand
Posted on: 02 June 2003 by undertone
Could you kindly point us to a website perhaps? Or a dealer where you bought it, or something?
Posted on: 02 June 2003 by Frizzlefry
Don't know about RTC brand, but I use a similar support. It consists of a sheet of laminated steel ( very solid and inert ) supported by either 3, 4, or 5 ball bearings in cups. Its available in a few sizes, unfortunatly naim needs the largest size at about £120.
The sound gained more weight, and was less harsh using my Meridian cd, as of yet it's not under my CDX2 - I'll let you know.
try:-
http://customdesign.co.uk/page36.html' Groovy '
Posted on: 02 June 2003 by hi fi fo fum
I use the I rap on Qs 4 and QS RR they make a amazing improvement ....tried one on a Frame but it did not work out ( one the glass and with out the glass on the Frame )
Posted on: 03 June 2003 by Mike Sae
ghunter,
have you considered the excellent Neuance shelves, which are made in your own backyard?
Posted on: 04 June 2003 by hi fi fo fum
Originally posted by ghunter:
Looks very interesting indeed, especially for the money. Anyone know where we can get the iRap in the US?
Graham
you will have to go to the web site, I do not think there is a U.S. importer....(the I Rap are pritty new to the market )
I RAP will work on a Lovan you will be happy
Emerald Audio Rescources is the Importer, phone # 905 880 7170
