digital camera - system photos
Posted by: Guido on 12 January 2002
hope it works
rega wallshelf - diy board on spikes
From top
CDI - 102 - pioneer F77 tuner - 180 - HiCap
mm board box and old grey snaics stored on the boxes ...
is that dust under the base? ![]()
As soon as the cabasse speakers have arrived at the main system (currently one room away)
I will torture you with new pics...
Nice weekend
regards
Guido
P.S: speaker change influenced by multiple reasons:
1. They are bu** ugly
2. they dominate the room
3. the bass is still boomy
4. the cabasse are smaller, quicker, faster
Was the 1st picture taken w/only ambient light?
I'm never comfortable with the electronics (and in particular the turntable) being so close to the speakers - do you get any problems from this?
Steve
Your system looks like it will suffer from the speaker to component distance.
I say again, No!
Now I've calmed down; some reasoned judgement:-
The trampolin was designed for inferior mounting surfaces. You have what looks like a very good rigid support.
Get it off. I, and many others prefer the Linn thing with no baseboard at all. Just screw the original little rubber feet into the corners and try it again.
I do know about the reputation of the trampolinn here.
The baseboard is mainly used to protect me from the evil caps on the valhalla board as I am moving the kit around a lot in the recent time.
The trampolinn feet will be removed in the near future - after a temporary "final" kit status is reached (when the akito I bought is installed).
The system positioning is a left over of my last tries of system positioning (moved the rack - was centered between the speakers). This way it sounds suoerior to the old setup - distance kit - spekers is limited by the length of the arm cable.
Today is nearly the last day of the B+W's in the system. With the smaller cabasse I have more flexibility with the speakers, they will move to the other wall of the room.
The distance lp12 - speakers is the result of me being too lazy to remount the wallshelf in a different place after the speaker repositiopning, as this setup sounded better than the old one I accepted the very small distance.
This is a work in progress.
Guido
Your lp12 really looks nice - I'm sure it sounds phantastic!
The stacked power amps on the floor, the stacked supercaps in the rack, not every box having a shelf on its own - couldn't the system perfomance be bettered/optimized if the 135s had a decent stand, the boxes their "own" shelves?
(adding a support, say a base rack?
The trampolinn will be modded - trampolinn feet removed - when the next turntable mod (akito) is on the schedule.
Today the cabasse have arrived - rearranging the room will have to wait...
Ana Caram "blue bossa" spinning in the CDI at the moment and they kick the b+w's a**es!!
patience, please
Guido
some equipment (not lp12, and probably not cdsii) may sound better on the floor than on any rack. something to do with "nearer to mother earth", but i jest... the important point is that you shouldnt dismiss the "floor" just like that...
enjoy
ken
I nearly forgot to answer the first question.
No, flash was used for the first picture, too.
I tried different methods to filter/cover the flash to make it less "evil" - it still is something I don't like - but as the winter in munich is dark, the menu of the camera is complex - I didn't manage to get a decent picture without. As the zoom is controlled by a very insensitive switch with lots of gain it's even gambling to adjust the focal length.
So quick and dirty pics - and photography class at film school is years ago....
Guido
Ken C: active SBLs are wonderful, aren't they?! Is the Prefix powered by a HiCap much different from powered by the 52?
Jun
when all is working OK, active SBL's are more than wonderful -- they are magic. my main naim system is in my office and i have my desk between the sbl's, which i gather is non-ideal, but hey, there are other priorities in life. they sound bloody good inspite of this. they are also appear to be a lot more robust than i ever imagined given their construction. mine went through quite a bit of man-handling while my active system was being installed -- they were moved, tilted, xover removed, put back, removed, put back, tweeters blown, etc etc... but they are still going strong (of course, blown tweeter was replaced, caused by faulty power amp). i am very interested in the new sbl replacement though, depending on how they sound and scale.
on prefix, i have tried hicap into BNC, hicap into aux and prefix straight into input 2b -- which is what i am using right now -- i am having a little more success with reduced RFI and it sounds a little better than i remember with other options. if you are going to experiment, please do be careful that you connect one and only one piece of equipment to input 2 -- i guarantee that you will be very sorry if you overload it. music will evaporate from your system. i know, because i made that stupid mistake once. fortunately naim came to the rescue -- FOC!!!! can you believe that???
what music are you listening to on your active system? i'd like to share other experiences with active systems if you are interested.
enjoy
ken
I started my active-experience with Credo/92/IXO/90s, changed to SBLs; that was not enough for them, so I upgraded the whole thing to the present state.
I am listening mostly to Jazz and Classic; many friends bring their Pop, Soul, Chillout, Bossa, CafeDelMar etc. I don't have really knowledge of all this genres...
Yesterday I listened to a system with Audiomeca CD-Transport, DCS-upsampling/DAC and Thiel 7 driven by some American 2500W-amps. It sounded very clean and I think the CD-kombo is quite OK. But there was no fun at all... Emotion and rhythm was not there... Maybe it was missing what naim-owners call PRaT? Anyway, I was very relieved when I played the same CD at home afterwords!
Jun
P.S.: What kind of RC comes with a brandnew 52 these days: the Flash??
I'm quite curious about your new speakers. I have never really liked B&W, so that you change them seems a wise turn imo. But I have also bad experiences with high sensitivity speaker designs (>93dB) and Naim. I have always heard annoying hiss with these combinations. Now I believe Cabasse also are pretty high sensitive speakers. Any comments on this?
I have the same set as you do and am wondering about new speakers also. My shortlist will probably comprise models from Epos, Naim and Monitor Audio. But I think Cabasse might be an option if hiss is limited, as I like their dynamic sound. Please, tell me more!
Greetz, Bas
there are a number of very useful messages by Ron Toolsie and Martin Payne on this subject which i will try to dig up.
i guess this is one of those issues where some advice from the orphean experts at naim might actually be very useful indeed.
whats your experience?
enjoy
ken
But you are the one who can do the comparison!
Jun
Although the sensitivity of the b+w is 93db there was no audible hiss - just quite.
Reading the posts on this forum I'd think the mains quality must be ok in my house/region.
The cabasse are rated with 88db - they are an older design, I think '99 or '98.
Bought them sh at my local dealer after auditioning their bigger range - especially the iroise was very impressing, lacking the right language my impression was: very involving, tunefull, all ind all fun.
The small one having the same qulities but having less bass (extension?).
Bought originally for the AV system I couldn't resist to test them in the main system - as the bass of the b+w never made me happy.
The result: b+w's dumped (already sold - will be picked up today) - cabasse promoted to main system.
No hiss with the cabasse, too.
Guido
