n-vi ( in stock )
Posted by: john R1 on 01 May 2006
browsing on the internet, see a naim dealer stating n-vi in stock, i presume these must be old stock, i would have thought with all the problems i have read about on the forums they would have been re-called until all the problems had been sorted out ?
Posted on: 01 May 2006 by Richard AV
Perhaps they mean they have a demonstration unit in stock?
Posted on: 01 May 2006 by john R1
thats not the way it reads richard, also i did not realise you could buy naim equipment by mail order, ?
Posted on: 01 May 2006 by Former member
nice to see your still at it on your day off richard john has not had alot of luck with his naim or his dealer perhaps he should try kent ps dont forget to ring me tues stuart
where did you see this in stock john
munch am i allowed to mention the retailer on the forums,
i think you will find, if you ring them they will not have any in stock and no they are not ment for mail order your dealer sets up for you all part of naim dealer serice its what you pay for
munch, if you lookback at some earlier threads not all dealers are willing to set them up, mine said he would only set it up if every thing was ready to plug straight in to the n-vi, some dealers are better than others,
Posted on: 01 May 2006 by JohnS
My dealer was awesome, arrived with a big toolbox suitable for a F1 pit crew, and, using my existing NAC-A5, created the speaker cables on the spot. Then we measured the speaker distances to set up those parameters and he used a sound pressure meter to measure (and equalize) individual speaker volume levels. He was there for 3-4 hours.
Of course you'll have to come out to California if you want that treatment Winker
Posted on: 02 May 2006 by Former member
john if you are not happy with your dealer why not change.this is top end equipment and not cheap,and you should get the service that goes with it
Posted on: 02 May 2006 by john R1
munch, there is only one other naim dealer in my area, whos to say he is any better, have been using the same dealer on and off for around 25 years, when i was into naim hi fi, sad to say i no longer have it, so now only use this dealer if i am buying certain brands ie naim etc,
Posted on: 05 May 2006 by Former member
john had phonecall from my dealer on wed will get nvi in next two weeks. fingers crossed
Posted on: 05 May 2006 by john R1
cheers for that munch, i knew that would happen due to go on holiday on the 19th, come back on the 29th so hopefully get mine then,
Posted on: 06 May 2006 by Former member
most people go on holiday john come back . thats it for another year. you have something to look forward to when you get back. hope you have a nice one.
Posted on: 12 May 2006 by Former member
Originally posted by john R1:
cheers for that munch, i knew that would happen due to go on holiday on the 19th, come back on tshe 29th so hopefully get mine then,
john igot my nv/i yesterday Winker
Posted on: 13 May 2006 by john R1
let me know your thoughts on it munch before next friday cheers john
Posted on: 14 May 2006 by Former member
set up took a while good read of book first.and half an hour bending naim speaker cable.put on roger waters in the flesh live high definition concert.it was mind blowing, to think when run in sound will be even better. then put on jarre in china concert from the forbidden city.the firstthx certified concert filmed in h/d all so mind blowing.i have played 10 or 12 cds this is one very good black box .still playing with set ups, not used dab yet got to get qed to make me a cable up.
Posted on: 14 May 2006 by john R1
cheers munch, what display are you using and how is it connected, i did not bother with the dab as i have read that the stations in this country use such a low bit-rate signal that at the moment its not worth having, wait for your next update, also what speakers are you using john,
Posted on: 14 May 2006 by Duncan Fullerton
Munch,
Do you have Sky connected to your n-vi?
Duncan
Posted on: 15 May 2006 by Former member
hitachi 42 plasma/monitor audio silver rsw12 sub /silver rs6 floor /fx /rear and rslcr center. dvi to hdmi. mark grant sub cable.
Originally posted by Duncan Fullerton:
Munch,
Duncan
no have not botherd .will when i get new hd box
Posted on: 15 May 2006 by nap-ster
I take you mean Sky audio off the optical connection?
Posted on: 15 May 2006 by Duncan Fullerton
Yup. Just want to know if the teething problems I've seen on this input are solved in the current boxes.
Duncan
Posted on: 15 May 2006 by AV@naim
Duncan
If you refering to audio being delayed from video on sky boxes. to correct this:-
would either require a video delay to allow the audio stream to catch up (not what the n-Vi does).
OR
putting the audio in a time-warp and forwarding in to the future (sadly not possible).
Posted on: 17 May 2006 by john R1
av@naim, it states in the manual it has a lip-sync feature what is that for then ? the way it reads it should compensate for video/audio delay problems
Posted on: 17 May 2006 by Duncan Fullerton
