Advice on second system
Posted by: Wind in ears on 28 March 2002
A Linn Clasik with Kans
or
A Nait 2, Kans and a CD3 and some kind of tuner.
I like to sound of my main system so want the second simular. Any experience of the above and advise appreciated.
Any suggestions for "warmer" sounding speaker that will sit harmoniously in this setup. (Please dont suggest an LP12/CDX upgrade, although the latter and maybe a P3 will probably come later). My dealer suggests Royd RR1 but I'd rather spend around £300 and put the rest on the front end.
Bruce
[This message was edited by Bruce Woodhouse on THURSDAY 28 March 2002 at 14:18.]
It sounds loads better than most peoples aspirational hi-fis from Currys etc.
Simpler to use, one box, one remote for CD and tuner and amp. I use one in the kitchen, with TV sound wired in too.
It replaced a over powering (for the room) Karik/Numerik/72/hicap/250 system.
Get a listen at a dealer - there are bargins to be had there.
DS
I would reiterate the Nait 2 advice as above. Great amp, crap 'pot'. Useless for playing at low volumes on CD.
I now use CD5 - Flatcap2 - 32.5 - 160 - Saras.
Suits me Sir.
I had problems driving RR1s with 72/hi/140 in a "medium" sized room. CDs had to be cranked to 1-2 O'clock, and LPs weren't loud enough with the pot at full clip! In any event, the cones bottomed out with typical electronic bass.
If your Nait2 can run them, I'll be very disappointed in my 140- time to crack out the whip! ![]()
That said, I recently heard them sounding fantastic off a 112/150. Dealer suggested that they weren't broken in when I was using them; I only gave 'em ~100 hours before giving up.
[This message was edited by Mike Sae on FRIDAY 29 March 2002 at 03:41.]
I guess it was designed with phono as its primary source and worked fine.
How about sort (optimise) the setup, and what about a CD3 instead of the Arcam? You'd be surprised what that will do in terms of fill-in and balance.
Rico - SM/Mullet Audio
Just a suggestion. ![]()
