Freeview box with hard drive?
Posted by: KeanoKing on 09 July 2007
Any suggestion, Only want to spend £150!
Help is appreciated.
Posted on: 09 July 2007 by Former member
Have a look at the Humax or Topfield.Affordable Satellite free pp
Posted on: 09 July 2007 by KeanoKing
With all these free view boxes does it matter what aerial you have? It is not for me but my aunt and dad want one, they both have an analog aerial
Posted on: 09 July 2007 by BigH47
In a good reception area a normal aerial is OK. If you are having problems the a "digital" aerial may be required.Approx £12 to £40 for a high gain one + fitting.It might be a good idea anyway as it should present a stronger signal and might be less prone to weather problems (heavy rain mainly).
thanks bigH47
Posted on: 09 July 2007 by Derek Wright
If you go to
http://www.ukfree.tv/starthere.php
and then to the "Can I watch Freeview" link on the right hand side and follow that thru you can find out if you will need to change the aerial to a wide Band aerial and may get and understanding of how much gain you will need to get reliable service.
Posted on: 20 July 2007 by Frank Abela
My biggest problem with digital broadcast is blocking (typically on plasma) or freezing (LCD). With analogue, all that happens is the picture quality decreases a bit, you get grain or a wobbly picture but you don't lose the continuity unless things are REALLY bad. With digital reception you can have a fab picture which will then suddenly break up or freeze which I find far more annoying/distracting.
Just looked at the ukfree site. Seems a bit patchy for reception for me (West reading), but of more concern there's no mention of Channel 5 in the ratings of signal strength...! Is Channel 5 not on Freeview???
Posted on: 20 July 2007 by Kevin Hughes
Save up for a toppy, you won't regret it. I will change the way you watch TV forever.
Kevin.
Posted on: 20 July 2007 by Stuart M
Yes a toppy is good BUT only if you like techy type gadgets.
Love mine but my partner doesn't. I upload the latest TOP and they get confused as buttons have changed!
Media PC (XP or Vista) is brilliant when it works but a load of rubbish when through some windoze fault it hasn't recorded what you wanted.
The best Freeview PVR (and one of the first) for ease of use I've seen was the Pace - but they stooped making it.
From reports if you want something simple Humax, something that's briliant if you put a bit of effort in Toppy, You want to network everything MediaPC - Aeus 510e is brilliant but their support is rubbish.
Posted on: 20 July 2007 by Former member
Frank yes chan 5 is on freeview though any bad weather or bad atmospheric conditions it will be the one chan that plays up ie freezing.quote:Originally posted by Frank Abela:
Regards Munch.
Posted on: 21 July 2007 by SteveGa
Have a look at this thread on Digitalspy. Basically the Humax PVR9200T or the Daewoo DSD-9503T are suggested, with the Humax being preferred. Word of advice having got my Mother a DVD/VCR recently - get a copy of the manual and keep it by the 'phone!
Steve
Steve
Posted on: 21 July 2007 by KeanoKing
SteveGa
Cheers for tip. And i hear what your saying about the manual
Posted on: 24 July 2007 by Frank Abela
Cheers munch, it doesn't get a mention on Hannington...
Posted on: 31 July 2007 by Harry
Humax PVR9200T. Fit and forget. Highly recommended.
Posted on: 31 July 2007 by Steve S1
quote:Humax PVR9200T. Fit and forget. Highly recommended.
Seconded. A couple of techno-phobe friends have just got one, it's excellent.
Steve
