Naim DAC with Vs Wavelength Cosecant V3 DAC?
Posted by: Li Ravicz on 25 November 2009
I realize that most of us haven't even heard the new Naim DAC yet much less had a chance to compare it to Wavelengths new reference DAC but I am if anyone has or would like to venture any kind of comparative analysis I'm "all ears." I plan to purchase one or the other to run my digital files from My Mac.
Li
Posted on: 26 November 2009 by james n
I'd chuck a Weiss Minerva / DAC2 into the mix too. The Wavelength is supposed to be a good one so please report if you do get to hear one.
James
Posted on: 26 November 2009 by Li Ravicz
Thanks for the tip on the Weis Minerva. I haven't heard it or the Wavelength yet but I did hear a demo of the Naim DAC and it was superb- Much better than the older model CDX2 in an A/B test.
Posted on: 26 November 2009 by ferenc
James
Minerva is discontinued, DAC2 is available. The successor of Minerva will be the new DAC202 in January.
Posted on: 26 November 2009 by DHT
Ferenc HI, what is the DAC202 do you have any details?
Posted on: 27 November 2009 by Eloise
Copied from a Greek forum
This email is to announce our new D/A converter, the DAC202, which will replace the Minerva D/A. The DAC202 has all the features of the Minerva plus some more. Here is an overview:
- Digital Inputs: AES/EBU or S/PDIF on 1 XLR, 1 RCA,
1 Toslink, Firewire
- Digital Outputs: AES/EBU on 1 XLR, 1 RCA, Firewire
- Main Analog Output: 2 stereo analog outputs,
one on XLR one on RCA,
- Headphone output on 1/4" Jack
- Level control main output: 4 coarse settings via relays (analog domain), fine setting via rotary encoder (digital domain). Level control can be defeated for the main output.
- Level control headphone output: 4 coarse settings via relays (analog domain, independent from the settings in the main output), fine setting via rotary encoder (digital domain).
- Wordsync input on BNC
- Wordsync output on BNC
Frontpanel controls:
- LCD display for display of sampling rate, input source, audio level, absolute phase, upsampling filter type, various menu items
- rotary encoder with push switch
- IR receiver
- standby LED
- headphone Jack socket
Special features hidden in sub-menues:
- transparency check (allows to check the bit transparency of a playback chain)
- setting of the coarse output levels (analog domain)
- dual / single wire selection for 176.4 / 192 kHz sampling rate
- display brightness
IR Remote control switches:
- power on/off
- volume up
- volume down
- input sources (4 switches for Firewire, XLR, RCA. Toslink)
- DAC upsampling filter type
- mute
- absolute phase
Sampling rates: 44.1 up to 192 khz / 24 Bits
Mechanics: The same looks and size as the Minerva.
The DAC202 also has a new D/A converter and new analog output stages compared to the Minerva. The D/A converter uses two converters per channel to gain in signal to noise ratio. We do not disclose any information on the specifics of the analog circuitry at this time.
I am sure the DAC202 will set the standard for computer based playback. With the remote control and the headphone output the DAC202 will appeal to many customers. It can easily replace a preamplifier.
Posted on: 27 November 2009 by DHT
Crikey thanks Eloise, I shall look forward to hearing that, no mention of price or release?
No idea about price, but on another forum Daniel Weiss states that the INT202 and the ATT202 and another product would be available before Christmas - not sure of the "other" product reffered to was the DAC202.
Eloise
Posted on: 27 November 2009 by js
The int202 is a computer interface, dig out for $1.2k without optional supply. The att202 is a passive pre with remote for $5k. The DAC202 should be same or more as it's a Minerva replacement.
Posted on: 27 November 2009 by james n
Sounds good - the only feature i miss from the DAC2 is remote control of the input switching.
James
James Hi, does the new one not have remote input switvhing. look at the remote control panel, the bit transparent featue might be useful, dual chips and a new analogue output!
I should have put - the only this i miss on the DAC 2 is... Smile
Posted on: 29 November 2009 by js
Just noticed that M-Audio has a ProFire 610 firewire/JET topology interface for under $400 US with drivers for everything. Very TC like.
I suspect the new Weiss DAC will increase in price vs the Minerva, though perhaps close, and the DAC2 to stay as is at it's lower price point. A bit more differentiation was probably needed.
Posted on: 29 November 2009 by ferenc
The ProFire 610 is just a little bit more plastic feeling than the Konnekt, the sound is very similar if not the same. It has one 6 outputs, so home theatre enthusiasts or digital (software) crossover users can use it Smile
Posted on: 30 November 2009 by mudwolf
Going back to Wavelength I read all the articles I could on them. I was going to buy but one dealer said most of his customers that buy tube amps end up selling them on due to problems of replacement. The other problem is it only has one input and one output. I realized I would probably be needing a second for my Bluray player and it would be nice to have a headphone plug.
Things are changing so fast in that world I'm going to sit back as I did for TV. I"m trying to un-complicate my life.
Posted on: 30 November 2009 by JYOW
Are you sure the Minerva is discontinued? As far as I know the DAC2 is the studio version and Minerva the "consumer" version with nicer case and feet
Posted on: 01 December 2009 by ferenc
Yes, I am absolutely sure, as asked Daniel Weiss few days ago about it in an email and he told me.
Posted on: 01 December 2009 by JYOW
WOw that is big news, especially since many of us have just bought a DAC2 or Minerva.
I wonder what the new DAC202 is like.
This makes sense since the Minerva does not justify the price lead to the DAC2.
I heard about a new attenuator with some fancy (gas driven?) control.
Posted on: 01 December 2009 by js
Looks like he's going upsampling on this one. Different circuit entirely.
Posted on: 01 December 2009 by Joe Bibb
I suspect that is the nub of it. The DAC2 is a very strong product at the price, the Minerva made no sense for domestic systems.
Joe
Posted on: 01 December 2009 by kent
I have audition a Wavelength Cosecant V3 with the numerator module and Transcendental for a month. I end up returning it to the dealer as it was not a good match for my taste and system matching.
Here are what I like about it:
- The sound is very coherence, with no single attributes calling attentions.
- It let you hear all of the details without being analytical.
- It make bad recording listenable.
- Ability to reproduce realistic human voice. The texture of the voices is unreal!
Here are the negatives:
- Only one input (USB)
- A MHDT Paradisea + come close to its performances for US$600. The differences are lower resolution on Paradisea+. I find the low bass on Paradisea+ is tronger but slightly less tuneful.
- I find Rock music sound funny on the Cosecant as it always sounded polite and pretty. The dynamic required by rock/ R&B is insufficient for my taste.
I think the Cosecant will be perfect for someone who only listen to singer/song writer type of music.
Now I am waiting for the Naim Dac, so I can audition it against the Weiss DAC2.
Posted on: 01 December 2009 by kuma
The Wavelength designer Gordon Rankin is a drummer.
So much for a musician designing a piece of hifi eh? Smile
Drummer? Interesting. I only know he has a scientific/engineering background.
Everyone has a sonic bias. Smile
Posted on: 01 December 2009 by mudwolf
The less edge sound is probably because of the tube I would believe. I really would want more than just my Mac Mini to be able to plug in.
I read all about them on the web he has some interesting ideas and technology but a bit limiting at this point.
Posted on: 02 December 2009 by BigH47
Drummer, a person who hangs around with musicians? Roll Eyes
