Sand... or something else?
Posted by: Mike Hanson on 16 May 2001
I've got a pair of Royd Squires to use with my home theatre setup. I was unpacking them this morning, and the instructions indicated that I should fill them with 3Kg of sand, or some material of similar volume. The old forum had a bunch of messages suggesting sand, ball bearings, marbles, fish tank gravel, and various other substances.
I would think that marbles or ball bearings would resonate at a common frequency, due to their consistent material and particle size. Sand has a varying particle size, and possibly varying material (depending on the composition of the sand), so it may be better in that respect. However, it may not dissipate energy as well as other stuff.
Are there any opinions out there on the best stuff to use? Thanks for any feedback that you can provide.
-=> Mike Hanson <=-
