Non destructive re-formatting,possible?
Posted by: BigH47 on 31 July 2007
My PC has a 2 H/Ds the 2nd 160g is an addition for storage pictures music etc.
The main (original) drive is formatted as 3 drives C:33g.D Backup 33g:,E Recovery 6g: approx.
I was reading some stuff to investigate why my PC was running slow. One of the major factors stated was making sure you had enough headroom on your main drive. They suggest 50% spare capacity. I have fiddled about,cleaned and moved various files but still only have 19 % spare(at least I can Defrag now).
My question as in the title is there anyway of moving the recovery and backup segments and reuse the space for the C:drive without destrying the format?
If the option is a new bigger H/D can the drive have the information put on it before it is installed?
TIA
Howard
Posted on: 31 July 2007 by Guido Fawkes
Howard
No I'm not going to say get a Mac: although I could lead you through it if you had. What you are asking to do is re-partition your disk. It is not peculiar to PCs, but is a desirable from time to time on all different systems.
Instead I advise you to check out a program like
Partition Magic. This is non-destructive so you could change how much space was given to each virtual drive. I think there are trial versions available. Though I wonder if this will make your computer faster - it certainly won't hurt.
I'm not sure how Windows works, but I'd assume it has a swap file that it uses when it runs out of memory. Ideally this should be on a different disk from the one you are frequently accessing. You'll know if you are having a problem with this as you'll hear lots of disk noise when you're not expecting it (thrashing). More memory is usually the best solution.
HTH Rotf
Posted on: 31 July 2007 by BigH47
Thanks ROTF more memory was the other biggie as regards slow machines. Sounds a lot easier to do too.
A MAC has not been ruled out when the next machine is required.
Howard
Posted on: 31 July 2007 by Derek Wright
Given that you have two spindles - you could buy a much bigger spindle - remove the second (data)spindle temporarily and insert the new spindle - you could then format it to the sizes you want and then copy the files across - then remove your small first spindle, move the new big one to replace it and reinstall your data spindle.
However I am not a Windows user so I do not know how you initialise the new primary spindle as a bootable spindle - in OS/2 it was done as part of the partitioning and initialising of the disk before you start the copy - so we need a windows person to detail how that part is done.
Posted on: 31 July 2007 by PJT
Howard,
Another option is to backup and restore your system disk. OK this is mini/main frame stuff, but it does work on PC's too. My dad's pc was running incredibly slow. I backed it up using GHOST, and then restored the partition.
The caveat is of course that you need to make the backup is file based (i.e. why I used Ghost) rather than block based.
Posted on: 01 August 2007 by BigH47
Thanks guys My mainproblrm is the PC was bought(in a rush) from PC world with a 5 years cover plan thingy,so I can't/shouldn't fiddle around in side.The guy has the machine for the health check says it needs resetting to factory spec. So he's going to backup data and re-install. They were very reticent to sell me a bigger H/D or more memory which was strange.
Looks like I'll have a lot of reloading to do later. Still this is the last time they will have the machine. We will start looking for a new one soon,might even be a MAC!
Posted on: 02 August 2007 by Willy
Try this program
http://www.ccleaner.com/ It's clears away all of the crap that accumulates as windows runs. Can be very effective af restoring system performance. It's free but if it works for you then you can/should make a donation.
Willy.
Posted on: 03 August 2007 by BigH47
I feel a complete idiot after taking my PC back to PC world as after I loaded the software to activate the wireless thingy, on bootup windows started and the the screen went blank. I picked the machine up to day and it was exactly the same.Why I don't know but I hit the auto refresh on the monitor and hey presto pictures again.Doh!
As previously thought most of my data has been lost due to one PC World "Tech Guys" not saving "My Documents" or any database files. Thankfully I have under 2000 CDs and LPs.
Bought a 500GB external drive today so hopefully I won't make the same mistake again.
I know it leaves room for a whole load of new mistakes.
Howard
