Dipping "toe" into murky DAC waters
Posted by: Willie B on 15 October 2009
Hi - I want to introduce some form of high quality computer-based source into my system eventually (Naim DAC/Mac Mini perhaps) but will start modestly and get to know what it all means. So I have bought a Cambridge DacMagic which I want to hook up to my iMac and feed into a second system comprising Nait 5i and n-sats. However, despite trawling through past posts I am still a bit confused about cabling so can I ask for advice on:
1. What is the best cable to connect the iMac to the DAC - Toslink Optical, S/PD or USB - and is it worth paying more for better cables (especially as I may want to trade up to Mac mini and naim DAC eventually)?
2. Do longer cables degrade the sound? The computer and hifi are in separate rooms and ideally I would put the DAC near the hifi so I could also feed TV and maybe other sources through it. I have seen 5m cables advertised but do they maintain the quality?
3. What is the best way to connect the DAC to the amp - 2 RCA to 2 RCA or 2 RCA to Din or is there an alternative such as Balanced Audio Outputs?
3. I also have bought a secondhand Squeezebox and wondered about feeding that through the DAC to get internet radio etc - what is the best type of cable to link the Squeezebox to the DAC?
Thanks for all your help
Willie
Posted on: 15 October 2009 by JYOW
>> 2. Do longer cables degrade the sound? The computer and hifi are in separate rooms and ideally I would put the DAC near the hifi so I could also feed TV and maybe other sources through it. I have seen 5m cables advertised but do they maintain the quality? <<
I think the general guideline is that it should be LONGER than 1.5m. Steve Nugent from Empirical Audio had a piece in Positive Feedback explaining why, (which I do not pretend to understand.)
>> 3. What is the best way to connect the DAC to the amp - 2 RCA to 2 RCA or 2 RCA to Din or is there an alternative such as Balanced Audio Outputs? <<
I use a RCA-DIN Hi-Line with good results.
I don’t think you can do balanced as the Naim amps are single ended. But when I had my Lavry I used a Flashback XLR to DIN cable, but of course it was running single ended, not balanced.
You have 2 choices, TOSLINK fiber or Coax/RCA. Most people think coaxial is better than TOSLINK, and I seem to recall Squeezebox master Sean Adams thought the same as well. But it would not hurt to experiment.
If you opt for TOSLINK, one TOSLINK cable I can recommend is the Van den Hul OPTOCOUPLER cable. It is reasonably priced and sounds very good for its price.
Posted on: 16 October 2009 by Alco
Hi Willie,
I have the exact same system as you. (SB3/DACmagic, Nait-5i, n-Sats)
I have an Atlas Element digital coax cable ( €40,- ) between my Squeezebox and the DACmagic.
I've never used a RCA-RCA between any source and my Nait-5i. Chord makes great RCA-DIN cables for Naim gear.
I have a Chord Cobra 2.
Together this combo sounds clear, open, highly detailed, with a tight bottom-end and voices sounding natural.
All in all, a very enjoyable system for an affordable price.
regards,
Alco
Posted on: 16 October 2009 by Willie B
Hi Alco
Thanks for the info - very helpful and look forward to hearing what the sound is like
Willie
Posted on: 16 October 2009 by Former member
I don't have a squeezebox so can't comment on that, but I use the mac's optical output into my dac, and its a 10 metre run.
Only compared it with an AE going into the dac, but there wasn't a huge amount of difference, though I did think the AE/dac combination was a touch warmer.
Thanks Avole - does the type/brand of optical cable matter or are they all pretty much the same and also what is an AE?
Willie
Posted on: 16 October 2009 by Occean
AE = airport express, an Apple device capable of streaming itunes wirelessly
There's been wars over the question of type and brand for optical cables and whether there is a difference!
Basically, provided they're well made, they're all pretty much the same. Mine cost about 17 euros from memory.
Thanks guys for help so far - further contributions appreciated although I am away for the weekend walking in Yorkshire Dales so likely to be off air until late Sunday
Willie
Posted on: 21 October 2009 by AMA
Exactly. The sound through VDH OPTOCOUPLER is so clear that possibly more expensive tosslink will not further improve it when feeding the re-clocking DAC.
Try to avoid cheap tosslink.
Posted on: 21 October 2009 by Willie B
I got the DAC to amp sorted with a spare Chord Cobra 2 RCA to Din I already had and I bought a Chord Codac co-axial to link the Squeezebox to the DAC.
However, I am still having difficulties getting the right iMAc to DAC cable. The iMac optical output is via headphone socket which Apple say is also an S/PDIF stereo 3.5 mini-phono jack - is this the same as mini-Toslink?. The DacMagic has 2 alternative digitsl inputs - either S/PDIF co-axial or Toslink. So my question is do I look for an S/PDIF cable or can I use mini Toslink-Toslink? All help very much appreciated.
Willie
Posted on: 21 October 2009 by james n
You need a Mini Toslink to Toslink. Chord do one which will do the job nicely.
James
James - thanks for the help - does the mini Toslink fit straight into the headphone socket on the iMac?
Willie
Posted on: 22 October 2009 by james n
Yep
Posted on: 22 October 2009 by SC
As do Wireworld now...
Steve.
Posted on: 22 October 2009 by Willie B
Thanks all - Chord Toslink - Mini-Toslink ordered so should be up and running as soon as it comes
Willie
Posted on: 22 October 2009 by Peter Dinh
Willie
It would be interesting if you let us know how it sounds.
Posted on: 25 October 2009 by JYOW
James
VDH Optocoupler also has a TOS to mini TOS
Posted on: 04 November 2009 by Willie B
Well my toe is well and truly dipped into murky waters and to be honest I'm a bit underwhelmed and a tad disappointed so far.
To recap I bought a Cambridge DacMagic and connected it to a Nait 5i by Chord Cobra 2 RCA to Din (to Tuner socket as CD & TV are connected into CD & AV sockets). I then compared 2 setups: first streaming wirelessly from iMac to Squeezebox which is connected by a Chord Codac co-axial S/PDIF cable to the DacMagic; secondly moving iMac near DacMagic and connecting it directly to it, without the Squeezebox, by means of a 10 metre Chord Optichord Toslink to mini-Toslink optical cable that fits the mini-jack headphone out/optical digital out port on my iMac.
My iTunes library was ripped Apple Lossless and is kept on a WD 1T external hard drive linked to my iMac by Firewire 800.
I am unable to directly compare the two set ups as I need the iMac connected to my router for the Squeezebox but then have to break the connection and move it to nearer the DAC to link into it for the second set up. However in both cases I have compared the sound to a CDX2 playing the same tracks.
I don't have the most critical hearing but in both setups the CDX2 aounds a lot better than the full digital approach - the 2 digital versions both sound somewhat veiled with less clarity and a muffling of drums, cymbals and less separation between the instruments. Not a bad sound but not as good as I expected.
From reading a lot of other comments I was expecting better sound than this and would appreciate any suggestions for improvements - do the cables and DAC need more time to burn in? Is the iMac optical output compromised in some way? Are the apple lossless rips inferior to other rips? I suspect the Squeezebox digital output is not of the highest quality but this doesn't explain why the sound with the iMac directly feeding the DAC is no better.
I was hoping that this first foray would give me encouragement to further develop a digital setup - perhaps with a MacMini feeding a Naim DAC but now I am not sure.
Willie
Posted on: 04 November 2009 by Eloise
Willie
Willie ... I think it's a bit unfair to expect a £225 DACMagic to sound like a £3000+ CD player - people say it punches above it's weight but not THAT far above it's weight. I would say (from not much testing of it) that it would be comparable to around £500 Cambridge Audio 750CD player ... but that's not a patch on a CDX2 ... you could also try USB connection to the DACMagic though generally the reports are this is not as good as via optical. If you want to compare the Squeezebox to the iMac, why not get a longer network cable back to your router ... should only cost a few quid.
I'm sure that a Naim DAC will get you closer if not exceeding the CDX2 ... even fed with Optical from your iMac.
Eloise
PS. 10m TOSLink is at the limits of the specifications but in most cases shouldn't be an issue.
Hi Eloise
Thanks for your comments and I expect you are right about the DacMagic but I also wonder if i can improve some of the other links.
Willie
Posted on: 04 November 2009 by likesmusic
re Toslink vs coax, particularly in the context of a squeezebox, here are Sean Adams (the designer of the Squeezebox) own words from the logitech forum:
"TOSLINK (as observed at a receiving device) is always worse, like +100 to 200 ps regardless of how good the source is. Coax is the only way to go if you care about jitter, although optical has the advantage of being inherently isolated which could help in a system having EMI or ground loop problems. That's why you get both... Vive la différence. "
(I haven't posted the link directly, as these seem to get deleted).
(And it's worth noting that if you are Sean Adams you are capable of designing a DAC that can take data from a computer without using S/PDIF, TOSLINK or USB Winker)
Posted on: 04 November 2009 by james n
Willie - check you have iTunes set up properly - all sound effects off, voume at 100%, in audiomidi (applications / utilities folder) set the output to 24bit rather than 16.
I've never heard the Dac magic but it seems well regarded. You could always try borrowing a Lavry DA10 which works very well with Naim kit. I'd also lose the 10m optical cable. If i had to use optical then i'd not go longer than 1m.
One more thing - have you played with the filter settings on the Dac ?
James
James
Thanks for your comments. I have now turned off Sound Enhancer (it was set to the mid-point) and turned up volume to full. I checked the output in audiomidi and it is already set to 24 bit. Do you think I should have gone for the AIFF or WAV encoder rather than Apple Lossless - I have plenty of storage space and they both offer more customised settings. I have played with the filter settings but they don't seem to make a big difference.
Willie
Apple lossless is fine so don't worry about that. Does it sound better now you've changed those settings ?
James
Posted on: 05 November 2009 by Keith L
As James says, you must ensure that iTunes' enhancer is off; sound quality is effected even in its flat setting.
Output from your sb3/dac should not be effected by the above. It should sound close to your cdx2. Have you tried your Cobra interconnect on your cdx2? Does the cable make any difference to your cdx2 sound?
