Small sub around £400-£500
Posted by: Bails on 21 January 2008
I have a naim system which I currently use for music and am very happy. I want to purchase a sub for home cinema use but do not have the funds (or the room) for a naim sub. As the room is relativately small I was thinking of either the M&K KX10-SF or the SVS-PB12 plus. I will use my Credo's as the front speakers. Has anyone used any of these sub's or can you recomend a good small sub for mainly home cinema.
Posted on: 21 January 2008 by daryl
Hi,Rel quake,good performance + good price.Daryl.
Posted on: 22 January 2008 by Bails
Thanks Daryl. The Quake is one of the subs I was planning to take a look at. As I currently do not have a sub I have directed the sound through the Credo's. My concern with the Quake and the M&K is that I would not notice much difference from the current set up. My thinking abount the SVS was it had a 12 inch driver. I will try and listern to them all.
Posted on: 22 January 2008 by von zipper
Hi Bails,
I'm not familiar with the SVS, but the KX10 is an excellent little sub - don't get carried away with the size of the drive unit -if it's a small room, you are better putting in a smaller sub with a nice fast amp unit behind it - you'll get a much tighter bass and less wallow. The M&K should suit nicely and it's exceptionally good value!
Posted on: 22 January 2008 by nap-ster
I've heard good reviews of the BK subs. Made in the UK too.
Posted on: 23 January 2008 by JAB
Take at look at the Epos ELS sub which is well within budget.
Posted on: 23 January 2008 by Bails
Hi Von Zipper
Thnaks for the info. Do you have a M&K? My only concern with the M&K was that the driver size was the same as my Credo's. As my processor sends the subs sounds to the Credo's at present I was unsure if I would hear much of a difference when I added a small sub such as the M&K.
I have not concidered either the BK or Epos subs. Will check out their web sites as I do not know much about these makes.
Posted on: 23 January 2008 by Chalshus
Since this is the HT forum, you might concider the SVS SB12 Plus. 13x13x14" size. £500.
Thanks Christian
This is one of the subs I was originally looking at. I have read some good reviews. But then again other reviews agree with Von Zipper that a smaller driver gives a tighter bass. My problem seems to be what path to go down??
A smaller driver have to move further up and down to move the same amount of air.
Only people who havent heard a nice, large sub tend to say this. Winker
I have a Bag End Infra-18. 18" driver in a sealed cabinet. Extended Low Freqency(ELF-technology) Tight as anything. Most articulated sub I've heard, at any price.
Anyways, if I was you, i would have bought two BK Gemini subs for £200 each. With two subwoofers, you will get much better in-room response.
Posted on: 24 January 2008 by count.d
I use the MJ Acoustics Reference 100 MKii. I think it's excellent.
