Snaxo 242 & SBL's
Posted by: Steve Crouch on 28 August 2003
Just wondering whether the settings in the 242 are the same as for the Snaxo 2-4 or whether the crossover settings are slightly different bearing in mind it is probably intended for the SL2 which I assume is a little different to SBL? It's just that now it is nicely run in the bass level seems to be a little recessed and I may increase the pot setting very slightly to compensate. Always found with the 2-4 that I preferred the factory settings.
Steve
Steve
