anybody tried Lowther with Naim?
Posted by: Mike Cole on 22 January 2002
Mike
Do you still have your Nait 3? It would also be interesting to read how a speaker with sensitivity of 102+ Db can be controlled with a standard Naim volume pot.
Regards.
Phil
I still own a Nait 3 but its been retired to the attic until my now 4 year old daughter wants a hi fi of her own. I'll use a Nait 5 and an Audiomat Arpege tube integrated amp.
4 year old is old enought for a Nait 3! My 18 month old daughter is praticing herself with a Nait 2 and meridian cdp! She like to put Cd in this top loader. I think by the age of 4 she will have the right to use my CDS...
Bernard Paquet
Judd
We had a 52 hooked up to Avante Garde Duos (horns) and the hiss was unbearable.
Don't know how sensitive the Avante Garde's are tho...
- GregB
Insert Witty Signature Line Here
Originally posted by Richard van Laar:
A good Lowter system can sound awesome but their sensitivity is so ridiculously high that controlling them with a "powerhouse" Nait will cause problems I think. You won't be able to touch the volume at all.
Richard,
the NAIT has adjustable sensitivity. Although this is designed for matching CD with LP, it is probably useful in this situation, also.
cheers, Martin
Originally posted by Rob Doorack:
I hooked them to a 112 /150 rather than a Nait 5........Unfortunately the Naim and Lamhorn combination was rather a harsh and tiring one.
I'm not surprised. I would think the AER/Lowther drivers would amplify any minute nastiness going on in lower-range Naim gear.
As far as the experience w/noise when using a 52, I wonder if that the amp(unknown) was the culprit. I would think a 52 feeding a 47 Labs gaincard, or low-powered tube job, would be pretty quiet.
I've heard good things about Lamhorns. Are they better than Medallians in the bass dept?
I want to die in my sleep like my Grandfather, not screaming like the passengers in his car.
I mean Listener. It's a good mag even if you don't specialize in SETs.
Rob, I would expect the volume control of the 5 series to be a lot better than the 3-series (matched resistors instead of a potentiometer).
