SuperNait - Sub Woofer Out.
Posted by: HuwJ on 29 April 2012
I've not used the sub out on the SN in the past but I do have a REL sub.
Some time ago I had the sub hooked up via the speaker cables but, while it gave some extra body in the mid range, when I disconnected it I found there was a lot more clarity and it was as if a veil had been removed.
This might have been caused by connecting the cables (speakeon?) to the amp speaker posts - I've since read that you should connect to the speaker post side.
I have floor standers (Focal 1027be) but the bass is still enhanced with a sub, so i thought I might try the SN output to see what happens.
Is anyone using the SN output? Does it help?
The manual says it is unfiltered so I assume that means there is no crossover and that the same frequencies go to both speakers and sub....
Any advice or thoughts appreciated.
Huw
