'Rusty' CDs
Posted by: DelR on 29 April 2012
While ripping my CDs to NAS I have come across a number of rusty CDs, as expected all manufactured by PDO. They look more golden than my Mobile Fidelity CDs!
However the only one so far unplayable has been Peek-a-boo CD single by Siouxsie and the Banshees.
Is this affecting many people?
Try burning the S&B CD to a new disc.
Type CD rot into the search,top left of the page .
Lots to read.
Stu.
CD Rot occurs in older disks. The aluminium layer that reflects the light of the player’s laser is separated from the CD label by a thin layer of lacquer. If the manufacturer applied the lacquer improperly, air can penetrate to oxidise the aluminium, just like iron rusts in air.
When the discs were cut the aluminum layer was too close to the edge of the disk and not sealed properly exposing it to oxidation. The index on a CD is on the inside the disk; disks are read from the centre out. With CD Rot, the last tracks are affected first. Another cause was labelling inks were chemically active even after UV curing, which interfered with the reflective layer causing more problems. The result is the CD will have lots of background noise., which rises and falls with the volume of the music and gets worse over time.
CD manufacturers changed their manufacturing process and materials so it should not happen with newer disks.
Get ripping and make a back-up and you'll be safe from such issues.
I have a few PDO pressed discs that are beyond recovery. I'm told that they will still be replaced for free where replacements exist.
Of more concern are the number of discs I have where there's creeping "black death", with black blotches and veins appearing, mostly from the inner and outer edges. Mostly it affects discs I bought back in the '80s.
I've had one disc affected by fungus (white spidery veins, around inner and outer edges), and a couple of older ones are showing 'pin holes' in the metal surface. Here's the good news: in all cases, I've been able to make a copy in iTunes / AIFF and burn a new disc without apparent loss in sound quality.
Two points:
A friend's toddlers rendered his ENTIRE CD collection completely unplayable by his CD player. But he successfully ripped them all (using iTunes) and now has access to all his music.
And yes, not worrying about CD care is a big plus of hard-drive based music.
As long as you keep back-ups - which is not so much a worry as a chore. I've settled for two backups: one via Raid1, and one manual on a drive that is stored separately.
I hardly run directly from drive, and prefer discs. I've had to burn three discs to replace damaged originals, and agree that the ability to do so scores high on the 'peace of mind' factor.
