Unable to move cursor on naim Forum iPad
Posted by: Dungassin on 02 May 2012
Not sure which forum to post this, but ...
LSO Live. What a misleading name for a record label. It implies that the recordings are live, but I seriously doubt it. Currently I'm listening to their box set of Sibelius symphonies, and very nice it is, too. Been on on their website because they apparently offer downloads. Low res only, though, as far as I can see.
There seems to be a little quirk with text entry using on posting to Naim Forums using my iPad. I can edit theTitle, but if I try to edit the body text while initially posting, then I seem unable to move the cursor - in fact, the cursor isn't even visible! This is using the forums via Safari. I can edit the text after posting. Very annoying.
Why don't I just use the Naim Forums app? Well, it's because I don't like the display, which doesn't fill the screen, even on it's 2x settingwhich gives HUGE text. Also, the app doesn't seem to let you edit a posting. ![]()
