hdmi/optical switch
Posted by: Andy1912 on 03 May 2012
I have a Thor hdmi/optical switch that I use to connect my satelite tv/blu ray/medi player to my projector and also pass the optical output through a DAC and then on to my preamp. The Thor has pretty much died after a couple of years of solid work and I see they are no longer available...
Does anyone have any recommendations for a replacement?
Andy
Posted on: 03 May 2012 by ursus262
http://www.octavainc.com/HDMI%...%204port_toslink.htm
Posted on: 03 May 2012 by Andy1912
Thanks that's great. It's a bit expensive - don't know of any cheaper ones do you? Say about £100 or so....
Andy
