Cable Lengths
Posted by: Flojoe on 10 May 2012
I have an option to have my DVD5 close to the NDAC and use a 'normal' length digital cable for music and then have to run a 3 meter hdmi cable to the TV for picture, or I can have the DVD5 below the TV and then have a 3 meter run of digital cable to the NDAC. So which is going to degrade the signal the least or is there no difference.
Posted on: 10 May 2012 by winkyincanada
3 metres isn't a big distance. Choose the option most convenient.
Posted on: 10 May 2012 by murkku
HDMI is less error prone than S/PDIF.
So, my vote goes for 3m HDMI cable, it's cheap too.
Posted on: 10 May 2012 by Geoff P
My TV is on a 6 meter HDMI cable and the picture is fine no problem with a decent quality cable.
I would keep the digital audio cable short if you can, just because it will cost less for a decent one like Naim offers if nothing else.
Posted on: 10 May 2012 by Flojoe
General concesus is the longer run of 3 Meters for the HDMI. When people say a good quality HDMI cable, what are the recomendations ?
'Wireworld' make quite a range of well thought of HDMI cables.That's what I have. Google them or 'Future Shop UK' who are a cable supplier with a large range of variously priced HDMI cables including Wireworld, with guidance on individual quality.
Posted on: 10 May 2012 by karyboue
I use Wireworld too.
They make DVI to HDMI cable, no need for an adapter.
I own a Starlight 5 series.
Silver Starlight 5 is said to be better and I couldn't find a DVI-HDMI but it does exist.
You can probably find some new old stock on eBay ...
Posted on: 10 May 2012 by Gale 401
I use a 5 and 6m HDMI cables to my Plasma screen with no problems.
I have used a 10m without any problems.
I also use a 5m digital optical and 5m digital coax cables to my DAC with no problems what so ever.
Stu.
Posted on: 11 May 2012 by Flojoe
Thanks for the replies.
Gale401 - what make of optical and coaxial do you use as a matter of interest.
