adding a podcast
Posted by: balma01 on 12 May 2012
Hi, I wish to listen  this podcast with may naim uniti, but browsing 'podcast by location' or 'podcast by genre' I cannot find it. There's a way to add a podcast to the naim list ?
Posted on: 13 May 2012 by balma01
Ive tried to click on  http://myradio.naimaudio.com, I've inserted  the macaddress of my uniti and logged in.
Pressing ADD ANOTHER STATION and inserted all the data about touchradio.
I've tried 3 different (and existing) URL
http://touchmusic.org.uk/TouchPod/podcast.xml
http://itunes.apple.com/podcast/touchradio/id80842701
http://www.touchradio.org.uk/
But always, when I select it from the naim uniti, I get CAN'T PLAY, STATION UNAVAILABLE
The only way to obtain something is  to add a single MP3 (ie   http://www.touchshop.org/touchradio/Radio79.mp3), in this way the uniti is able to play the mp3, but I wish to add the list of the podcasts, as happen for every podcast you can find browsing PODCASTS BT LOCATION or BY GENRE. Can somebody help me please?
Posted on: 23 May 2012 by osprey
I have also a couple of podcasts which are not in the list which I would like to follow. Have you manged to solve the problem or found anything else about this? I sent an e-mail inquiry to vTurner about this via the help function in their web site already awhile ago but so far they have not given any answer.
Posted on: 23 May 2012 by balma01
Osprey, I'm happy to not be alone...I posted this issue some days ago but nobody helped me so I was thinking to be the only one wich wish to add a podcast.
Anyway, I do not have a solution yet, I've asked to the  support and I'm waiting for an answer.
Posted on: 24 May 2012 by Jon Myles
I've found in the past that an e-mail query gets absolutely no reply . Their customer relations rank is zero. I know that's not much help. Sorry. Save you waiting, though. Godot will come sooner.
By the way. I meant vTuner for the lack of response. Not Naim.
Posted on: 25 May 2012 by balma01
I've  received a response from Naim support that says that v-Tuner does not support adding Pod Casts.
So I'm  solving downloading to my pc the podcast with Itunes and streaming it via upnp.  It works perfectly.
Posted on: 25 May 2012 by osprey
Thanks for sharing the information you have received.
