SBtouch via USB into nDAC, anyone?
Posted by: matpip on 13 May 2012
Hi there,
I just discovered that there is an app to enable the Squeezebox touch output via USB (in 24/192 btw).
Does that mean that the SBT can be linked to the nDAC via a USB cable, hence not requiring the coax or optical digital connection anymore? if that's the case, is the USB connection any better? Usually the USB stick direct into nDAC is highly regarded. I was wondering if anyone tried already...thanks
