Vortexbox and SuperUniti
Posted by: Member on 15 May 2012
I know Naim recommends hardwiring over WiFi for its network players, but I'm unable to run an Ethernet cable from the router to my SU right now. So my question is, can I connect the VBA directly to the SU via cat5 cable? Will they communicate with each other or there has to be a router in between them? Thanks.
You could get a airport express and hardwire that to the superuniti. The airport express can communicate wirelessly with the router.
If it all works perfectly, don't mess with it.
You could technically connect the two directly with an Ethernet cable *IF* you were able to set both units to appropriate static IP addresses / subnet masks manually ... however as this is something that really requires you to be au-fait with the fundamentals of Ethernet networking then it's not really something that I would suggest that you attempt unless you really do understand what you are doing - and in that case then you'd know that it could be done and how to do it. ![]()
If you did do this though then your Super Uniti would have no connection to the Internet for Internet radio.
I'm not sure quite why MangoMonkey suggests using an airport express to connect the SuperUniti to the network as the SuperUniti has wireless networking built in (as you are already using).
Ideally (and normally) you would connect all the units in your network to a router - the router then acts as a central point for the issuing of IP addresses for your network (so that everything can talk to everything else) and also as a gateway so that everything that needs to can access the Internet.
We always advocate a wired network connection as wireless networking (and Ethernet over mains) are simply not reliable.
Phil
That's unusual for me! ![]()
Have a good one... ![]()
Phil
Phil, I do not know where MM got the idea but I remember reading some previous posts where it was suggested that this variation would give a better result i.e. to use external WiFi receiver instead of built in one (connection being NAS - cat5 - router - WiFi - AE - cat5 - NU/SU). This however, based on your comment, might be some kind of myth so I might not bother to try atfer all then.
Thanks for your input, saves me some time to be spent listening to music instead
Two reasons to use an airport express:
a) FUD reason: Isolate the entire home's network from the streamer. Its an electrical connection after all. And all the cables act as a nice antenna picking up who knows what...
b) Take the wireless networking load off of the streamer.
If you have a ae lying around, no harm in trying and reporting back what you think.
