Connecting HDX to Virgin SuperHub Question
Posted by: GraemeH on 16 May 2012
I've just received a Virgin SuperHub and imminently await the arrival of my HDX.  I've run an ethernet cable from the hub and my understanding is:
1.  With HDX power off I connect the ethernet cable from the hub to the back of the HDX
2.  Power on the HDX
3.  Do I then need to input the SSID name on the Hub into the HDX?  How do I do this if it is necessary?
4.  Does the HDX 'remember' the network after power off?
More questions to come I'm sure but thanks in anticipation.
Graeme
Posted on: 16 May 2012 by james n
It's not wireless so no need for SSID. The hub will allocate an IP address to the HDX. It should just be plug and play
Posted on: 16 May 2012 by GraemeH
Brilliant - Thanks!  G
Update - the Superhub has a very poor wireless range compared to my Belkin router.  I cannot believe Virgin are marketing this as 'wireless'.
I've set it to modem-only and reinstalled the router!
Best way. I'm trying to avoid the Virgin modem upgrade until I have to.
Posted on: 18 May 2012 by garyi
It works fine just as a modem, not much use for routing or wireless.
Posted on: 18 May 2012 by Tog
I have a Superhub connected to an Airport Extreme - great speed - rock solid wireless - TogServe/Uniti connected via cat6 and switch. Job done.
Tog
