Transferring CDs to Unitiserve
Posted by: CSI_Basel on 24 May 2012
Been doing this for the last 2 evenings and I'm still at the letter A!!
At this rate it's going to take at least a month!  It's a lot of work...
Posted on: 24 May 2012 by GerryMcg
It took me 3 months to complete. Glad I had the Unitiserve for ripping, the PC would have been a pain.
Posted on: 24 May 2012 by Claus-Thoegersen
I found the process of just putting a new cd in without really thinking about it, very easy, just check the server after 8 to 10 minutes and feed it another disk, or when I was in the room when I could hear the disk was ejected.
I think i started out with the 20 to maybe 30 disks I was listening most to at the time, and after that like you started out from A.
Claus
Posted on: 24 May 2012 by Guido Fawkes
It took me about 6 months using mainly XLD on a Mac, but once it is done it is d ,,,,, advise you to make a back-up as you go, just in case. Even if you never use the back-up it is comforting to know it is there. The UnitiServe is an excellent box and it'll be worth it it in the end.
What is more it was quicker than copying all my vinyl to cassette
Posted on: 24 May 2012 by Jan-Erik Nordoen
Think of it as a ritual, similar to cleaning vinyl records one at a time, safe in the knowledge that the end result will be better sound.
Then fire up the nServe app on an iPad (preferably an iPad3) and revel in your new powers to explore and access your record collection.
Jan
> preferably an iPad3
iPad2 is OK ....
Originally Posted by Guido Fawkes:
> preferably an iPad3
iPad2 is OK ....
True, but the UnitiServe sounds better when controlled through the iPad 3
Posted on: 24 May 2012 by CSI_Basel
> preferably an iPad3
iPad2 is OK ....
And it has to be a white one!
Posted on: 24 May 2012 by rjstaines
> preferably an iPad3
iPad2 is OK ....
I chose a WHITE iPad 2 after auditioning both a black one and a white one.
Sounds like an upgrade to iPad 3 (white) should be on my Christmas list then... especially if Naim have shipped my NDS by then.
Posted on: 24 May 2012 by engjoo
Why will ipad3 sound superior over ipad2?
Posted on: 24 May 2012 by Chaton
children play
Posted on: 25 May 2012 by garyi
Pah! Wont happen, thats the problem with multi use devices.
Posted on: 31 May 2012 by CSI_Basel
120 discs later and i'm now at D. Think its time for a backup just in case
Posted on: 31 May 2012 by Jon Myles
Skip E.
It's a known fact there are absolutely no good records by artists whose name begins with E.
The letter I isn't a winner either. Unless you count Ian Dury - but that should be under D, surely?
Posted on: 31 May 2012 by Tog
Jon - had you down as an Enya sort of guy
Tog
Oh bugger.
Just found Echo & The Bunnymen.
Ignore all previous posts.
Who's Enya BTW Tog? Does she know three chords?
Jon - Everything But the Girl, Eurythmics, Earth Wind and Fire - surely a man of your sophistication has all these and more Es Enya knows lots of chords but most importantly lots of expensive marketing executives Tog
Posted on: 31 May 2012 by Klout10
What about Eels and Elbow?
Michel
Posted on: 02 June 2012 by CSI_Basel
Michel
Eels great band and dont forget Steve Earle!
Posted on: 02 June 2012 by DenisA
and not forgetting...
Editors, Electrelane, ELO, ELP, ENO,, Melissa Etheridge, Bill Evans, Terry Evans
Jon, I think you may get even more help
Posted on: 05 October 2013 by Lungholt
Elvis?
Posted on: 05 October 2013 by Plinko
Does the Unitiserve rip while serving other music?
Posted on: 05 October 2013 by Harry
Not forgetting Earth And Fire, the Dutch prog rock band. Although most people have never known them, let alone forgotten them. And there's Electronic - if you like that sort of thing.
iPad size, version and colour make little difference, but if you don't chose the right bespoke leather case you will be missing out.
The HDX-SSD will serve or play happily while ripping. I expect it's the same for everything else.
Thanks Harry.
Posted on: 05 October 2013 by nitrous
Eloy
Posted on: 05 October 2013 by Bart
Yes it can serve and rip at the same time.  And it can serve whilst I'm copying music to its Downloads folder.  If you get a lot of stuff going at the same time the hdd can be taxed, but my NDS buffers quite a bit of data so it's quite immune to momentary lapses.
When I used the uServe as a player into the Naim Dac, it was slightly prone to skipping if I was playing and ripping at the same time, however.  But in this mode it was playing, not serving; no substantial buffer in the Dac I believe.
