NDX's display screen issue
Posted by: marcobb on 03 June 2012
Hi,
Anyone the NDX's display screen suddenly scratch on the text and turn dark never show up when reboot the machine ? (But the sound still working perfectly)
Marco
Hi marco
I have had two ndxs and never had the problem you describe.
Ray
Hi caftan,
How the cable loose? disconnected? Physical loose ?
Marco
Oh, my NDX also upgrade the broad before but over few month, would you let me know what is the root cause about it ?
Thanks a lot,
Marco
Dear All,
Today i bring my NDX to the local dealer to verify and they use around 15 mins to fix it.
They just reinstalled all of the cables that related to the display, they fixed. ![]()
Marco
I think I'm having the same problem. My question though is how do I remove the cover to get at the innards? There appear to be two bolts on the base, one in the right rear corner and the other just right of centre with a rubber cover (as you look at the fascia).
