UnitiServe upgrade to v1.6c - rip or play mode?
Posted by: Ray Hughes on 04 June 2012
Hello all,
Has anyone performed this yet, if so can anyone tell if it matters whether you're in rip or play mode?
Many thanks
Ray
Posted on: 04 June 2012 by rjstaines
Yes.  No.
Hope this helps.
Roger
That'll be... yes I've done it and No it doesn't matter, the US recognises a software CD and won't try to rip it or play it !
Roger
Posted on: 04 June 2012 by Ray Hughes
Roger,
Thanks, didn't think it mattered but wanted the re-assurance of someone who had performed the upgrade.
Cheers, Ray
