HDX Glitch
Posted by: sktn77a on 05 June 2012
Hello: I have and HDX 2x500 with the upgraded PCI card and RAM. The unit will occasionally show "Error" on the LCD display and won't play or burn anything inserted. If I put the unit into standby and switch it off and then back on again, it's fine. This happens about once a month. The outside of the case is quite warm to the touch and the system temps are in the 50's (processor in the 60's) centigrade. Anybody else have a similar experience or offer any advice?
Also the little rubber bumper on the front of the drive tray keeps falling off. I could just glue it back on but I don't know which glue sounds best...............
Seriously, though, any recommendations? It appears to have that dry 3M tack-um stuff on it right now.
Keith
