Naim can now play ALAC!
Posted by: chrismuc on 08 June 2012
After reading the many forum posts about Naim not being able to read ALAC (Apple Lossless Audio Codec) I was quite surprised that my UnitiiQute (via MacMini and Playback) had no problem playing them.
A mail from the Naim support made it clear:
"All our 24/192 products will play ALAC"
Thank you!
Posted on: 09 June 2012 by badlyread
Welcome to the party! You are quite late however.
Neil
Posted on: 10 June 2012 by Zinger
I believe ALAC has been supported for a while on streamers ... Just not on the DAC
Posted on: 10 June 2012 by Goon525
Now wouldn't it be nice if Naim delivered on the commitment to support AirPlay on the SU etc?
Posted on: 10 June 2012 by Lontano
Absolutely. It's the only way they will get any money out of me on streaming kit.
Posted on: 10 June 2012 by Richard Dane
Goon,
I'm not aware of any specific commitment to Airplay from Naim, just an expression of "hope to have" in a comment made by Paul Stephenson last year.  No promises.  These things are never quite so simple as just dropping it into the box or adding a few lines of code and you're done.  There are all kinds of hoops that need to be jumped, particlualy with regard to licensing, and of course that ever present thorn of whether including it adversely affects overall performance, and if so, how do we make it so it doesn't...
Well, I accept there are a lot of difficulties, not least licensing. But I think the MD's remark (at least as widely reported) was a bit more positive than "That'd be a nice idea".
Posted on: 10 June 2012 by AndyPat
Ahh! The age old problem of large companies not living up to their end in their dealings with small companies still alive and well. Perhaps some letters to the good folk in California would spur them on.
I see the likelihood of a being that 'dreams of electric sheep' gaining a foothold, despite being later to the starting gate.
Andy
Posted on: 12 June 2012 by 0rangutan
Worth noting that while all of Naim's 24/192 products will play ALAC, they can't play them at 24/192!
FLAC is supported at this resolution, but ALAC is only up to 24/96.
Posted on: 12 June 2012 by Gavin B
Is the ALAC capability as a result of the hi-res boards update or software updates?
My Qute is quite an early version that I haven't updated at all yet.
Posted on: 13 June 2012 by 0rangutan
ALAC comes with the new board (and by extension the new software).
The Qute board upgrade is expensive and so probably only worth it if you really need to use ALAC, or 24/192.
You can upgrade the software for free at home or at your dealers.
Posted on: 17 June 2012 by Elija123
@goon: I don't think that Naim will ever implement Airplay. They will rely on their own app n-serve although I think that a STREAMING DEVICE should support streaming formats. And airplay however IS a streaming format. It's like you have a mobile with which you can only phone to o2 or Vodafone...ODD!
@Lontano: With me the same. No Airplay - No buy of a Naim Streamer!
Posted on: 17 June 2012 by Guido Fawkes
+1
I understand the problem for Naim as there are lots of formats, but Airplay would a great addition to its streamers, as is playing ALAC., Whether you use Apple products or still have a PC, you should be catered for.
However you can add Airplay support through an AE as a stop gap.
Good point - we need to support all the formats: shame the world couldn't agree on FLAC as the standard, but .... well, it never seems to work that way .... I have a Betamax video about format wars, luckily I was able to convert it to HD DVD to preserve it
Posted on: 17 June 2012 by Tog
ALAC was important once - but flac is all one really needs. Tog
Posted on: 17 June 2012 by George Fredrik
ALAC is still important for me!
ATB from George
I still use both, but wish iTunes supported FLAC ... perhaps if I ask Apple nicely... as I would like a FLAC only system.
I hope the NDS works well with a Vortexbox ... if it doesn't then I'll need to look elsewhere, maybe the Linn KDS or just stay with the Mac Mini/Naim DAC ... a DAC 555 would be nice = NDS without the streamer.
Still UQ works a treat with VB so can't see why NDS wouldn't ...
Posted on: 18 June 2012 by Phil Harris
Originally Posted by Guido Fawkes:
".... I have a Betamax video about format wars, luckily I was able to convert it to HD DVD to preserve it "
That just made my day!!!
Phil
Posted on: 19 June 2012 by tonym
Off-topic; nice Chimaera Phil. A 4-litre?
Posted on: 19 June 2012 by Phil Harris
Thanks - it's an 18 year old 4.0HC that I've had for about two and a half years ... it was bought with nothing at all needing doing to it. (Famous last words!)
It's had all new discs, pads and calipers, new coolant hoses, new radiator, new coil and ignition amplifier, new clutch, new alternator, a "sports exhaust" (solid pipes in the silencer box rather than perforated), just had the old ECU / distributor / airflow meter / engine harnes ripped out and replaced with a nice modern CANEMS ECU and coil packs, just had the dash reveneered (fitted that last weekend)...
..it still NEEDS new carpets, new hood, interior trim repairs (after a cat got in under the soft top and tried to scratch its way out), new air intake hoses, new headlights and - ideally - a respray to get rid of all the various scratches and blemishes.
She's a daily driver - goes to work with me every day - and I guess does about 15,000 miles a year (the odometer hasn't worked for the last two years - best add that to the "needs fixing" list too...)
Love it to bits though ...
Phil
If only it was ... but my Alpine IDA-X305 head unit and 160Gb iPod Classic say otherwise.
Phil
Posted on: 19 June 2012 by Richard Dane
Yes, if only itunes would support FLAC - it would make life so much easier.  Right now I tend to have all discs ripped to either WAV or FLAC for the NDX but also doubled up in ALAC for various iPods that get used for travelling and in the car.  I have found that importing into itunes is not so straightforward, so I usually end up ripping twice which is a bit silly I guess..
Posted on: 19 June 2012 by Frank Abela
Indeed, looking like I may have to do that too which is a right FAFF! Perhaps I should have chosen an alternative player for on the go, but even there most portables don't seem to support FLAC, even Sony's much vaunted Walkman-Z.
Frank.
All opinions are my own and do not reflect the opinion of any organisations I work for, except where this is stated explicitly.
I use dbPoweramp to batch convert convert my ripped files over to ALAC and embed the cover art - haven't yet worked out how to get it to automatically populate the "Album", "Artist", "Title" and "Track Number" fields so far but a quick second pass through with "The Godfather" sorts that...
Phil
Phil, "The Godfather"...?
Posted on: 19 June 2012 by Foot tapper
Ah, formats again and the question of compatibility with itunes.
After reading many, many posts on this, there seems to be a consensus that:
  • WAV sounds equal to or better than every other format
  • FLAC is either equal to WAV or a good second best
  • ALAC is Apple's preferred lossless codec but is no better than (and many think lower sound quality than) WAV & FLAC
  • Which seems to leave AIFF as the only format that itunes is happy with, that Naim streamers are happy with, that has metadata that most devices can read.
However, does anyone actually know how the sound quality of AIFF compares to FLAC, unless you are of the "it should be the same as WAV, FLAC & ALAC" school.
I will shortly be listening to an NDS at Signals, so hope to hear for myself...
Best regards, FT
