How to tell if I have a 24/192-capable Uniti
Posted by: munkee on 11 June 2012
Hi,
I just bought a second hand Naim Uniti. It was advertised as having support for 24 bit / 192kHz files but I can't get any of my 24/192 FLAC files to play. Is it broken or is it in fact the 24/96 version? I suspect it's the latter, since 16/44 and 24/96 files play just fine, but is there a way to tell for sure from the system information? It's running software version 3.13. In System Status I can also see the following information...
CD SW: 7.05
BC SW: 2D11891
DPCB: DR 003-003
MPCB: MR 002-002
Thanks in advance.
