UnitiQute Questions
Posted by: Chris Bell on 16 June 2012
Can a UnitiQute connect to my Uniti Serve wirelessly over my network?  I'm trying to figure out if I can use it as a wireless headphone amp/streamer?
Thanks.
Posted on: 16 June 2012 by AndyPat
Indeed it can and a very fine headphone amp it is. Use mine with AKG K702 headphones for a very fine bedtime listen. Serve needs connecting to the router then the Qute just needs adding to your wireless network as per manual.
Andy
Posted on: 17 June 2012 by Gale 401
Thanks.
Hi Chris,
The answer is yes.
I have friends that use them in there systems as streamers and for the radio.
Stu.
