N-Serve & People
Posted by: Martin+ on 23 June 2012
Is there really no "PEOPLE" in N-Serve?  -I have only just installed it, but I cannot find it.
This is a problem for me because I can find tracks by searching in Desktop Client (DCI) which I do not find using N-Serve.
also is there a way to "get back" to the top level view in NServe?
Posted on: 23 June 2012 by Claus-Thoegersen
Have you tried the track search found if you choose the more tab?
The closess to people must be performers.
The easiest way to get out or back must be using the tabs at the bottum of the screen. I must admit I use the DTC 90 percent of the time.
 Claus
