Newbie help..upnp
Posted by: Dablk on 23 June 2012
HellO, hope to be picking up a superuniti in the next two weeks.
Sorry if this is old ground but I can't find a thread which explains upnp servers that makes sense to me. If someone knows a link Iwould appreciate it. If there is an idiots guide link anywhere that would be great
I just need setup guidance? And help to decide what I need to buy. The plan is to be able to run without a pc being turned on, save for initial file management. I need a music library in flac on the nas. The nas will be hard wired into a network switch which the superuniti will also be wired into. The wireless modem router is also hard wired into the lot.
I also need to be able to create an mp3 mirror of the the flac on my laptop for iTunes to use.. But I don't need the superuniti to be associated with this at all.
Also what is the best way to manage files on a nas? Is it no different to just creating a directory tree like on a normal c: drive?
Do the zen units on eBay work well? They look like a poor mans uniti serve to me which would be ideal for my budget. Does ripping on the drive make life a lot easier? The nas drive is in going to be under the stairs so noise isn't really an issue.
All input most welcome.
Thank you for reading this far
Chris
