Uniti outputs??
Posted by: Guto Orwig on 24 June 2012
Can the 'line outs' of the Uniti be used to supply a Naim preamplifier? From reading the manual it looks that the signal is taken from the dac and before the onboard preamp.
"The stereo line output is intended to be connected to a recording device. It is taken before the NaimUniti volume control so does not reflect volume control changes. The output always reflects the selected input signal."
Posted on: 25 June 2012 by naimUnT
Yes, I believe it can! The signal is line level with maximum output which the external preamplifier will then control.
Posted on: 25 June 2012 by NickSeattle
You could also use the variable out to AV Unity Gain on a NAC, if you prefer to use the Uniti POT.
Posted on: 26 June 2012 by Guto Orwig
Nick,
Is there a variable out?
The manual says the uniti volume control would have no effect.
Do you mean the pre-outs that would usually go to a poweramp?
Guto
Posted on: 26 June 2012 by NickSeattle
The DIN, called Preamp Out appears to be variable; the RCA, called Line Out, appears fixed.
