Almost there with the streaming, just a little more help needed
Posted by: chris2000 on 02 July 2012
Hi all
Thanks for all your input on NAS locations. I was very fortunate to be able to borrow a streamer from James at Tom Tom at no notice (thanks James!) to be able to put the theory to the test over the weekend. So far the wifi seems to be doing a fine job and I had no issues getting it to recognise the Synology and get Nstream up and running on the ipad.
My last hurdle then is getting the Synology audio station software and in turn the nstream to correctly read the tags on my wav rips which I'm doing through DbPoweramp. At the moment I can get the system to recognise the track info, the album and the album art however the track number is getting mixed in with the track title and the artist info is not being read. Does anyone have a default tagging structure that the Synology player can pick up or other tricks to make this work?
I also did a few rips with uncompressed FLAC and it picks up all of the information fine. I've read that uncompressed FLAC is basically a wav file with a FLAC wrap to allow the meta data pick up. If that's the case is there any reason to try and use wav rips over uncompressed FLAC?
