DVD 5 Stopped working.... Help
Posted by: Trevor on 06 July 2012
Came home after a couple of days away and DVD 5  had W DOG on display.
From forum this said about the processor stopping working.
Switched it off and back on and the power light keeps flashing and nothing works.
Pushed a few buttons on front and it said SOAK but still does not work and light keeps flashing.
Is it looking like a trip back to the dealer?
They say things come in 3s. Meridian F80 died, Electric Toothbrush stopped working and now this.
Posted on: 07 July 2012 by Dungassin
Have you tried a factory reset?  I no longer own a DVD5, but it's in the manual (under setup IIRC)
Posted on: 08 July 2012 by Trevor
Thank you for the info Dungassin. Found the reset info here https://forums.naimaudio.com/di...ent/1566878606539265
I took the DVD into my local dealer Saturday morning so hopefully they will give it a try and see if it cures the problem.
