UPNP and Internet radio drop out wirelessly
Posted by: Patrick Lam on 15 July 2012
Hi guys,
Does anyone face the following problem when streaming music wirelessly.  My gear is NaimUniti.  When I stream music wirelessly, the buffer drops from 100% to 90% and then 70% and so on but will resume normal (100%) quickly.
The buffer level is not stable when streaming music or listening to internet radio especially Radio Paradise(320k).
I tried to connect my Uniti with my access point by using a lan cable.  This happens the same and I don't know why.  Can anyone explain and help me to solve the problem?
Thank you very much.
Patrick
Posted on: 15 July 2012 by marcobb
Originally Posted by Patrick Lam:
Hi guys,
Patrick
Hi Patrick,
I think it is the wireless connectivity signal issue, did you put your uniti nearby the router to test it again ?
And would you help to test the wireless and wire connectivity to the Naim choice 320kbp Radio?
Any buffer drop on your environment ? If yes, which one media type drop ?
Marco
