NDS and N-Stream
Posted by: HTM_1968 on 18 August 2012
Hi,
I have a new NDS to replace my nDAC/ND5SX
. I'm having an issue with N-Stream V3.0 installed on an iPad. The NDS is connected via a switch to a Virgin Media Superhub and functions perfectly in that it sees my QNAP NAS and Vortexbox (and any other device on my wired network) and plays back without dropouts.
The issue with N-Stream is really irritating. To access the new features I need to have UPnP compatability mode in N-Stream turned on. When I have this enabled, my QNAP NAS does not appear in N-Stream. When I disable the UPnP compatability mode, the QNAP appears. As the QNAP contains the bulk of my FLACs, this is a pain.
EDIT: I am also getting the SERVER not available message for anything N-Stream sees but the NDS is playing from that server the time N-Stream claims it is unavailable......
The NDS sees the QNAP irrespective of the UPnP mode setting in N-Sync so I am making do with the remote and the screen to select files, but it would be nice to be able to use the iPad and the new features such as playlists.......(sigh) OK it would be just nice to change tracks without leaving the comfort of my sofa as I'm too old to read the screen on the NDS from further than 2m away.
FWIW the issue is mirrored on my iPhone with N-Stream, so it is not an iPad problem
Any suggestions or solutions to this issue would be gratefully received, as rebooting the NAS, iPad etc and even power cycling the NDS has not proved effective, which exhausts my PC related problem-solving skill set.....
Thanks in advance
