Use Supernait in surround sound
Posted by: ajay1223 on 27 August 2012
How can a Supernait be used with a Yamaha AX1 to drive the main speakers during a movie
Posted on: 27 August 2012 by Maxi Me
Front pre-out from AX1 to the AV input of Supernait.
Posted on: 28 August 2012 by ajay1223
Thank you, wouldn't it be main out ? Also does this turn off the sub out on the supernait ?
Posted on: 28 August 2012 by Maxi Me
Looking at the back panel picture on google, there are a couple of outputs that probably do the job. Doubt it turns sub-out off from Supernait, that will just be taking signal from AV input and amplifying out through whatever it normally has attached. If your sub is attached via more than one amplifier, then you will need to be careful.
I have successfully got the supernait to work in AV mode, you must use the remote, the sub out is turned off, the REL can handle the LFE and HI-LO phono as they are different plugs and it is designed to handle them, only one will be used at a time anyway, thank you again
